08-13-2008 01:55 PM - edited 03-03-2019 11:08 PM
How important is it to have a routed connection between 2 switches in a routed server farm access layer?
So, what we have are 2 server farm switches in an HA configuration with L3 uplinks from each to a routed distribution layer, as well as L2 trunks between access switches.
Question:
How important is it to have a routed connection between the 2 routed access layer switches?
My answer is that it is important. The logic is that the 2 switches are in an HA setup, and that makes it all the more imperative that the IP routing and forwarding information in each switch be the same -- identical/synchronized/converged. This will speed up network convergence in the event of a failure of one of the access switches.
There are others who say that for an ACCESS layer, it is not so important because -- and this is where I get fuzzy regarding the stance -- that L2 switching is faster than routing and therefore....I dont know the rest of the argument. maybe you can fill me in. :-)
Victor
08-14-2008 11:47 AM
Gotcha.
I thought maybe there was an industry best practice, a rationale that permeates the industry, that says that it is a good idea to have that routed connection.
Victor
By the way, I didnt rate your post with a 3. I gave it a 5.
08-15-2008 12:46 AM
Regarding best practise, Cisco have a Design Guide on this very topic that makes excellent reading.
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns107/c649/ccmigration_09186a008073377d.pdf
Chapter 6 covers the access-layer, where all options validated by Cisco are described in detail - and I couldn't see that routed connection mentioned anywhere...
Andrew.
