Router 1941 password reset procedure not working
I have a cisco router 1941 having password recovery disabled and i forgot the password??
It is not going to rommon mode and neither the mode of reset router
i tried Cntl + Break and Cntl + C both are not working
can someone help???
7 Replies 7
Leo Laohoo
The IOS of the 1941 is stored in a CF in Slot 0.
What happens if the CF is removed?
After removing flash, it is going is boot loop, but rommon is not coming
Console into the router, remove the flash, reboot.  Post the entire bootup process.
The same is repeating again and again
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO1921/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/-1(On-board/DIMM0) bit mode with ECC enabled
Readonly ROMMON initialized
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Compact Flash0: Not present
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
PASSWORD RECOVERY FUNCTIONAyu7gtuigLITY IS DISABLED
Leo Laohoo
  1. Power down the router.
  2. Power up the router.
  3. When the line "Readonly ROMMON initialized" appears, keep bashing the Ctrl+Break key like mad.
Tried the same 10-12 times but neither rommon appears not the router reset prompt
Are you using a USB-to-Console adapter?
