Router 2811 Tech Question
ARGJ
Hi, guys thanks for your time and help
i have a router 2811 for my principal connection for some 7 remote site
in this moment i have a 10mbps Wan connection using a HWIC-1GE-SFP
which is the maximum amount of constant bandwidth can handle this router on port HWIC-1GE-SFP
i made this question becuase i wan to upgrade from 10mbps to 20mbps i can do that whit this router ?
i send over this router and interface: Video, Data, Voice, etc running OFPS
thanks
  Cisco says
Q. What is the maximum throughput on the Gigabit Ethernet HWIC?
A. The HWIC bus interface is limited to 400 Mbps of full duplex. The  actual throughput of the Gigabit Ethernet HWIC is limited by the  throughput of individual platforms. Under bidirectional traffic of 1518  bytes or larger, the Gigabit Ethernet HWIC can support up to an  aggregate of 350 Mbps on Cisco 2811 and 2821 routers, 400 Mbps on Cisco  2851 routers, and 500 Mbps on Cisco 3800 Series platforms.
      However,you should check router performance as well. IMHO,C2811 can handle 20M link with features running on it. Let's check the file I attached.
HTH,
Toshi
ok, i see thanks for your time and help
