04-22-2011 07:07 AM - edited 03-04-2019 12:09 PM
The router 861 Fast ethernet have support for
wan protocol L2TP ?
Can I configure the router to use L2TP wan protocol to communicate the wan FE port to my ISP ?
If yes wath is the way ( CLI or Cisco E[press Professional Configurator ?)
Can be helpwith the configuration to see the CLI configuration.
Thanks for thr help,
Daniel
04-22-2011 07:24 AM
Hello Daniel,
Why do you want to configure L2TP on this 861? L2TP LAC&LNS is only supported on high end routers like 7200s. Is the L2TP going to be used to connect to an Internet connection? Is this located at Israel?
Regards.
04-22-2011 07:31 AM
Yes is to connect to ISP in Israel but you say the 861 FE is not support this connection , rigth ?
04-22-2011 07:48 AM
Daniel,
Isarael's ISPs (Netvision) uses a different L2TP setup, it is not the same L2TP as in LAC & LNS. Here is a sample I had for that type of connection:
pseudowire-class dialer_to_ISP
encapsulation l2tpv2
ip local interface gi0/1
ip pmtu max 1470
interface gi0/1
description "---LINE_TO_CABLE_MODEM---"
ip address dhcp client-id gi0/1
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface Virtual-PPP1
ip address negotiated
ip mtu 1420
ip nat outside
no cdp enable
no ppp chap wait
ppp pap sent-username USERNAME password 0 PASSWORD
pseudowire
interface gi0/0
description "---To_Lan---"
ip address 192.168.8.1 255.255.255.0
ip nat inside
interface Dialer0
no ip address
no cdp enable
ip route 0.0.0.0 0.0.0.0 Virtual-PPP1
ip route
I hope this helps.
04-23-2011 03:43 AM
Hi Juan
The ISPs in Israel use the MS L2TP/ PPTP mode with "optional encryption( connect even if not encryption) " or the configuration in a router with support for L2TP (ej. Netgear) . I configure the router with the following info : "user ID","Password " ," L2TP Gateway" ,"MTU = 1392","Connection Type = Continuous", "Idle Time =10 minutes"
On the configuration you send me I have to make any change ? If yes where and what change?
I thanks you for your answers ( Gracias !)
Daniel
04-23-2011 08:05 AM
Daniel,
De nada!! I would recommend trying the configuration I sent by just changing the username/password and using "L2TP Gateway" information as the ISP's next hop IP address.
Regards.
