Router booting problem
Arup Dutta
hi all,
        i have 2811 router and flash is 64MB but i want to upgrade 128MB.i am able to upgrade IOS into this but not reboot itself.
here is attached all details please find it and help me out.
PS:router is boot properly by 64 MB flash
24 Replies 24
Leo Laohoo
I think your IOS is corrupt.  Download it again.
hi,
thank toy for your reply but i have been tried with many IOS but problem
remain same.
please comment
On Sat, Apr 10, 2010 at 2:43 PM, leolaohoo <
How big is your CF again?  How big is the IOS you are trying to load?  Upload the IOS that require only 64mb.  Try using TFTPDNLD process as this is alot faster.
How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMMON Command
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
please see bellow the error
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -66
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
On Sat, Apr 10, 2010 at 3:03 PM, leolaohoo <
Ok then.  Reload the router and let it go into ROMmon.  On the first prompt type "i" and hit return.  Load the IOS again using TFTPDNLD.  Make sure you load the IOS that requires only 64mb and not the larger one.
hi,
Actually i want to upgrade my flash 64MB to 128 MB
please comment
On Sat, Apr 10, 2010 at 3:14 PM, leolaohoo <
Ok.  Now I'm getting confused.  Your post shows that the router is unable to boot but you are more concerned about the CF upgrade from 64mb to 128mb.  Am I understanding your issue?
If this is your issue, my question is this:  Is the 128mb CF formated by the router?
Actually i have no much more idea but i know this router is support 128
MB flash and my DRAM is 512.
please tell how i know "128mb CF formated"
please reply
On Sat, Apr 10, 2010 at 3:19 PM, leolaohoo <
After type "i" same error is coming
What is the result of the command "dir flash:"?
hi,
rommon 1 > dir flash:
dir: cannot open device "flash:"
please reply
On Sat, Apr 10, 2010 at 3:23 PM, leolaohoo <
Right, this can mean either the following:
1.  There is no CF in the CF slot of your router; or
2.  CF is faulty
Have you tried loading the IOS into the DRAM using the "-r" option?
hi,
my 64MB flash is properly working on the same router but problem is only
when try to upgrade 128MB flash.
On Sat, Apr 10, 2010 at 3:27 PM, leolaohoo <
Hi Arup,
Kindly leave the 128mb CF out of the picture as of the moment.  The current issue is that your router WILL NOT BOOT.  I would like to solve this issue first before tackling the 128mb issue.
If you say that the 64mb CF works in other routers, kindly insert the 64mb CF into the router and see if it will boot.
