router can perform static route load balance
yangfrank
Dear All
I am not sure a question. I need your idea and help. The question is if the router can perform static route load balance. I tested it. The result showed No. If you have any experience on it, could share it with me. I also post my result here. Thank you
Hi ,
 you can enable ip cef for load balancing
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
share me your router configuration .
Sandy
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally they can, but you generally need different next hops.  How did you "test".
