router cisco 1921/k9 features
I wish to use a 1921/k9 as a router on a stick. Inside interface interconnects up to 9 VLAN, and performs the routing.
Does the 1921/k9 supports trunking and VLANs (I think it should support 16 VLAN, but I am not shure) or I should choose 1921-SEC-k9?
Routing performance is the same both on 1921/k9 and 1921-SEC-k9? (I think I'll use static  routes or RIP, it is not a large network)
Massimo
Richard Burts
Massimo
As far as I know the 1921 with the IP Base license should support your VLAN routing requirement.
Yes the routing performance would be the same. With the 1921 it is the same hardware and the same IOS code running whether you are using just the IP Base license or the Sec license. What the Sec license does is to allow you to activate additional capabilities. But it is the same hardware and same software for both.
Rick
Rick
