Router Config question for point to point T-1 connection
burleyman
Level 8
Level 8
I have this config on our routers for the serial interface on the near side and far side.
interface Serial0/0/0
description Point-to-Point T-1 farside
bandwidth 1536
ip address 10.146.19.38 255.255.255.252
encapsulation ppp
service-module t1 clock source internal
service-module t1 timeslots 1-24
service-policy output VoicePolicyP2P
interface Serial0/3/0
description Point-to-Point T-1 nearside
ip address 10.146.19.37 255.255.255.252
encapsulation ppp
The question I have is one side is missing the Bandwidth 1536 and service-module t1 clock source internal....will this cause any problems and should they be configured on both sides?
Mike
tdrais
Level 7
Level 7
You should always use LINE clocking if you can the internal clock should only be used if the telco clock is not good which is very rare.
The bandwidth statement has no effect on the transmission rate on the line... the timeslots do all that.
The reason you want it correct is the service policy may have options that depend on it being correct. So it depends on what you policy VoicePolicyP2P has in it. It is best policy to set bandwidth to the correct value but does not cause a issue in many cases if it is wrong.
tdrais
Level 7
Level 7
So I should use service-module t1 clock source line.....correct. The VoIP policy if for voicemail only, phone calls do not go over the P2P. Will changing this cause the connection to go down?
Mike
line is the default so you don't have to put it in. On the side that is already internal just check to see if you are getting any errors or slips. If not you can leave it at internal, the ends do not have to match since the clocking for a router is not end to end you only have to talk to the telco equipment. If you need to change it you may take a very small outage (seconds) as the line resyncs.
You can change the bandwidth at any time and it will cause no outage. I guess you could in theory mess something up if you put a very low value in and you were policing traffic as a percentage just type carefully
Thanks for your help.
