router (config-vpdn-req-in)#protocol pppoe (not find ) cisco 887va
CSCO11649089
i try to config adsl
i used this config
Configure ip routing, ip subnet-zero, and ip classless in order to provide flexibility in routing configuration options.
(config)#ip routing
(config)#ip subnet-zero
(config)#ip classless
Configure the global Point-to-Point Protocol over Ethernet (PPPoE) parameters.
(config)#vpdn enable
(config)#no vpdn logging
(config)#vpdn-group pppoe
(config-vpdn)#request-dialin
(config-vpdn-req-in)#exit
(config-vpdn)#exit
Configure an IP address and subnet mask on the Cisco DSL Router Ethernet interface.
(config)#int ethernet 0
(config-if)#ip tcp adjust-mss 1452
(config-if)#ip address 41.32.58.169 255.255.255.248
(config-if)#ip nat inside
(config-if)#no shutdown
(config-if)#exit
Configure the ATM interface of your Cisco DSL Router with an ATM permanent virtual circuit (PVC), encapsulation type, and dialer pool.
(config)#int atm 0
(config-if)#pvc 0/35
(config-if-atm-vc)#pppoe-client dial-pool-number 1
(config-if-atm-vc)#no shutdown
(config-if)#exit
(config)#int dialer 1
(config-if)#mtu 1492
(config-if)#ip address 196.202.4.105 255.255.255.248
(config-if)#encapsulation ppp
(config-if)#dialer pool 1
(config-if)#ppp pap sent-username 1********@tedata.net.eg password ******
(config-if)#exit
Configure a default route using Dialer1 as the outbound interface.
(config)#ip route 0.0.0.0 0.0.0.0 dialer 1
i don't find pppoe protocol red line
Peter Paluch
Hi Ahmed,
New IOSes do not use that kind of configuration. That is why you don't see the red line. Simply skip the entire VPDN section and you should be fine. The necessary PPPoE configuration is done on the PVC 0/35 - the PPPoE client is activated there, and that is all that is needed.
Best regards,
Peter
thanks
now i don't need NAT .. the pc will take real ip
create vlan with real ip
so the config will be
(config)#ip routing
i don't need that right !!!!!!!!!!!!!!!!
(config-if)#exit
(config)#int atm 0
(config-if)#exit
(config-if)#exit
interface Vlan10
right this config or have any mistake
nowi have another message
when i create vlan
196.202.4.105 overlaps with dialer1
i need to make this ip  196.202.4.105 gateway to pc without nat static ip
how can i solve it
new update
interface Vlan10
and it's run
but when i ping in yahooo
196.202.4.105 unreachable
and in racert stop in 196.202.4.105
