Bookmark
Subscribe
1045
router configuration
sir_ulrick
Hi everybody,
I have a Cisco  and I need to sync this router with a PTP server in my network. Reading about this configuration, I found different configurations and profiles and I don't understand how setting it exactly. Neither I know if I need to configure the router in transparent mode (End-to-end transparent clock) to sync with the master clock (PTP server) .
Im trying to check configuration from these links but none works (from IE2000 switch from packet tracert, I didn't find any router to work with PTP from packet tracert)
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/system_management/521_n1_x/b_5k_System_Mgmt_Config_521N1x/b_5k_System_Mgmt_Config_521N11_chapter_0110.pdf
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/timing-and-sync/63x/b-network-sync-r63x-ncs540/b-network-sync-r63x-ncs540_chapter_01.html
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/sysman/configuration/guide/b-sysman-cg-asr9k-61x/b-sysman-cg-asr9k-61x_chapter_01100.html
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/sysman/63x/b-system-management-cg-ncs5500-63x/b-system-management-cg-ncs5500-63x_chapter_01100.html#topic_j2r_kz3_nbb
Thanks all
looking at the command reference linked below, it looks like PTP is not supported at all on that platform...
https://www.cisco.com/c/en/us/td/docs/solutions/GGSG-Engineering/15-4-3M/config-guide/Configuration-Guide/AppendixCLI-Ref.html
Hi George,
thanks a lot for your quick reply. Ont this router is compatible, but I'm not sure about how set it using different links attached previously.
which PTP do you have available on the 5915 ?
Sorry, my bad.
I confused IOS version. You are right, is not compatible.
