router excessive netbios icmp
dreams_as_money
Hi mates
I have got  problem with my branch router  which is sending excessive netbios icmp request to ghost ip
I have monitored it with wireshark  for two days and  it peridically sending  icmp request to     ghost ip that doesn't exist in my topolgy
could  someone tell  what's going in my branch router?
6 Replies 6
cadet alain
Hi,  could you post your config.
Regards.
Alain
Thanks  for reply
version 15.2
service timestamps log datetime localtime
service password-encryption
hostname ************
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.152-1.T1.bin
boot-end-marker
logging buffered 100000
aaa new-model
aaa authentication login default local enable
aaa session-id common
no ipv6 cef
ip domain name *************
ip cef
password encryption aes
c
redundancy
no ip ftp passive
ip ssh logging events
ip ssh version 2
class-map match-any L-LIMIT
description LIMIT4VIDEO
match access-group name LIMIT
policy-map L-LIMIT
description POLICY4VIDEO
class L-LIMIT
  police 3500000 3500000
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key *********** address ************************
crypto isakmp keepalive 10
crypto isakmp peer address ****************
crypto ipsec transform-set ************** esp-aes esp-sha-hmac
crypto ipsec profile **********
set transform-set *****************
interface Loopback0
description LOOP
ip address *****************
interface Tunnel0
description To-->HUB
no ip redirects
ip mtu 1440
ip nhrp authentication *************
ip nhrp map multicast **************
ip nhrp map ***************************
ip nhrp network-id 104
ip nhrp nhs *******************
ip nhrp shortcut
ip nhrp redirect
ip ospf network broadcast
ip ospf cost 10000
ip ospf priority 0
ip ospf 100 area 0
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100004
tunnel protection ipsec profile *****************
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Wan
ip address ******************************
ip nbar protocol-discovery
ip ospf authentication message-digest
ip ospf authentication-key 7 0529092D0E7F7E2F
ip ospf priority 0
duplex auto
speed auto
service-policy output L-LIMIT
interface GigabitEthernet0/1
description Local
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description Local
encapsulation dot1Q 2
ip access-group 2 in
interface GigabitEthernet0/1.2
encapsulation dot1Q 3
ip address 10****************************
interface GigabitEthernet0/1.3
description ***********
encapsulation dot1Q 4
ip address ********************** secondary
router ospf 100
priority 0
network************* area 0
network ************ area 0
network ************* area 0
network ********** area 0
ip forward-protocol nd
no ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
control-plane
alias exec traffic sh ip nbar  protocol-discovery stats packet-count  top-n  10
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 3
access-class 1 in
privilege level 15
transport input all
line vty 4
access-class 1 in
privilege level 15
password 7 10634A0B0E44085955547B
transport input all
scheduler allocate 20000 1000
ntp authentication-key 100 md5 0138031D755C162D2E6E 7
ntp server ***********
time-range ******
periodic Monday Tuesday Wednesday Thursday Friday Saturday 8:00 to 20:00
Dreams,
What tools did you use to detect this? to my knowledge theres no reason for the router to be pinging anything unless it has IP SLA enabled.... which I didn't see. Do you have a spare router, with the same IOS maybe you should boot it up and see if it does the same thing, or maybe just replace the router out there as it's behaviour is odd. IMO
Tony
lgijssel
Level 9
Level 9
Do you perhaps have an ip helper address configured on the router which equals this ip address?
regards,
Leo
Here is conf.
That doesn't help really.
Please show us what this is about; any debug output or so perhaps?
