Router Inter-VLAN Routing only ping to the gateway
iespinosan
Hello!
First of all clarify that I'm quite new with networks and I'm using web interface, no console. I have read some other posts but are for Switchs or differents scenarios.
Im trying to config a Cisco RV345 with 2 VLANS.At the moment I have:
- VLAN 1: 192.168.2.0/16
- VLAN 102: 10.10.102.0/24
- VLAN 103: 10.10.103.0/24
And I have the problem that from default default network(VLAN 1) I can ping the gateway of the 2 VLANs, but I can't get past it.
From the router Diagnostic > Ping 10.10.103.1 OK but 10.10.103.2 Failed and is the same from any other computer in VLAN1.
The Inter-VLAN Router is enabled. So where is the problem here?
can you post a screenshot of the LAN --> Vlan Settings page ?
Hello, of course I can.
where is 10.10.103.2 placed in network?
Good luck
KB
‎10.10.103.2 is an AP connected to a switch that is connected to the router but I also tried directly to the router with the same result.
Actually what I want is that Unifi Controller with the IP 192.168.2.6 connect with the AP with IP 10.10.103.2 If I'm not wrong the router would be capable to do that. But there's where I have the problem.
