router isr 4300 cisco problem enbaled two interface
Dhikra Marghli
Level 5
Level 5
Hello
I installe fedora21cloud-unsigned.ova in router and  i  want to enable the two  commande !!!
" interface virtualportgroup "
" interface virtual-service "
on router ISR 4300 cisco but t i can't to enbale !!
so How i can configure the two interfaces on isr 4300 cisco ???
so i wait a reply and answer ASAB from expert  router isr !!!
thanks in advance
the system doesn't like the virtual service instance name. Try the line below:
Router#virtual-service install name fedora21cloud flash:fedora21cloud-unsigned.ova
26 Replies 26
Dhikra Marghli
Level 5
Level 5
i want a help from expet router ISR 4000 cisco !!
thanks in advance
where did you copy the .ova to on the 4300, a harddisk ?
copy usb0:fedora21cloud-unsigned.ova harddisk:
thanks to reply me !!  NO
copy the .ova to on the 4300,  to flash     because word  " harddisk"   is not exsit in router !!!
so how i can enbale the two commands !! and what do you think the solution !!
show version
Router#show version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 2 hours, 22 minutes
Uptime for this control processor is 2 hours, 23 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 uck9 Permanent uck9
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDO2307A2Y7
2 Gigabit Ethernet interfaces
4 Voice FXO interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
30310160K bytes of USB flash at usb0:.
Router#
what do you think about router !! what is the solution !!
i wait a help and a reply !!!
Please can some one answer me !!
i wait a reply about this router 4321 cisco
thanks
is the virtual service activated ? What is the output of:
sh virtual-service list
And how did you install ? Like this ?
4331#virtual-service install name fedora21cloud-unsigned flash0:fedora21cloud-unsigned.ova
4331(config)#virtual-service fedora21cloud-unsigned
4331(config-virt-serv)#activate
Router#show virtual-serv
Router#show virtual-service list
% Invalid input detected at '^' marker.
Router#virtual-service ?
% Unrecognized command
this router does not accept any command that you send me !!!!!!!!!!!!!!!
i need a solution for this router 4321 that allow activate virtual-service and configure two interface !!!
please i wait your reply !!
Please  , i wait a reply and answer  !!
thanks
hello
i send a picture please can you check !!
thanks
This problem need expert router can help me
some one answer me and give me what i can doing !!!
Hello
Please can You reply me
I wait the problem resolved !!
type out the command in full:
and press <ENTER>
What is the result ?
Also, post the output of 'dir flash:' (or whatever name your flash has).
ok thanks to reply me !!
Router>en
Router#$ll name fedora21cloud-unsigned flash0:fedora21cloud-unsigned.ova
virtual-service install name fedora21cloud-unsigned flash0:fedora21cloud-unsigne ^d.ova
Router#dir
Router#dir fla
Router#dir flash:
Directory of bootflash:/
11 drwx 16384 Feb 18 2019 06:58:26 +00:00 lost+found
16289 drwx 4096 Dec 9 2020 10:29:40 +00:00 .prst_sync
12 -rw- 486645440 Feb 18 2019 07:08:13 +00:00 isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
260609 drwx 4096 Feb 18 2019 06:59:24 +00:00 .installer
97729 drwx 4096 Feb 18 2019 07:21:10 +00:00 core
81441 drwx 4096 Feb 18 2019 07:19:32 +00:00 .rollback_timer
13 -rw- 0 Feb 18 2019 07:19:41 +00:00 tracelogs.271
342049 drwx 4096 Dec 10 2020 06:57:10 +00:00 tracelogs
14 -rw- 30 Dec 10 2020 06:57:29 +00:00 throughput_monitor_params
15 -rw- 171120640 Dec 9 2020 11:03:32 +00:00 fedora21cloud-unsigned.ova
3149967360 bytes total (2331222016 bytes free)
So please , what i can doing and what is the solution for this problem ISR 4321 cisco !! i wait your reply and answer
thanks
Please , i need a check and a reply  because it is not find any solution !!
thanks
