Router keeps shutting off on it's own and then turns back on its own aftre certain period of time...
CyborgX_CZ
Hi Guys,
I just start experiencing this weird behavior on my Cisco 2811 Router. Recently I added to my home learning lab Cisco 2811 with integrated Cisco EtherSwitch Service Module (nme-16es-1g-p). Router has just basic configuration to join my home network and it's mainly used to power via POE three 36XX series lightweight access ports that are part of my vWLC. Like I said this is my home lab that I put together to help study and to be able try things on real devices so no big deal, but still I'm wondering why this happening.
I'm using PRTG to monitor my network devices and some of the internal sensor via SNMP and there is nothing weird in the log prior to these unexpected shut offs. The temperature is around 32C and everything is in normal. The router usually shuts off 2-3x time a day some time it comes back after 30 minutes some times it takes up to 2 hours but eventually it will boot up on its own. I have another 2811, 2x 1811, ASA5510, 3750, 819, 2950 etc... that have been running continuously for months with out any issue.
Any idea how to trouble shoot this and is any of you ever seen something like that? Included 2day graph of the power supply and temperature where you can clearly see the area and time line when the router went dead
Roman
What I'm saying is the power source feeding the router could be at fault or the power supply.
When I'm saying the power source feeding the router, I meant everything:  From the circuit breaker of the power outlet, to the power strip to the power cable.
Try moving the power feed source to another power point (without using the power strip board).
9 Replies 9
Leo Laohoo
Post the complete output to the following commands:
1.  sh version; and
2.  dir
Router:
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(11)T        4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 26-Oct-07 19:38 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
R4-2811 uptime is 2 hours, 48 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-11.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 245760K/16384K bytes of memory.
Processor board ID FTX0911A0FA
2 FastEthernet interfaces
1 Gigabit Ethernet interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
Directory of flash:/
    1  -rw-        6245  Nov 25 1997 13:01:30 +00:00  backupconfig
    2  -rw-         660  Nov 26 1997 09:33:12 +00:00  vlan.dat
    3  -rw-        1038   Oct 9 2007 15:02:52 +00:00  home.shtml
    4  -rw-        1823   Oct 9 2007 15:02:54 +00:00  sdmconfig-2811.cfg
    5  -rw-      113152   Oct 9 2007 15:02:54 +00:00  home.tar
    6  -rw-     1475584   Oct 9 2007 15:02:58 +00:00  common.tar
    7  -rw-     6141952   Oct 9 2007 15:03:08 +00:00  sdm.tar
    8  -rw-     1697952   Oct 9 2007 15:03:20 +00:00  securedesktop-ios-3.1.1.45-k9.pkg
    9  -rw-      416354   Oct 9 2007 15:03:28 +00:00  sslclient-win-1.1.3.173.pkg
   10  drw-           0   Oct 9 2007 15:24:44 +00:00  ips
   17  -rw-    41977164  Dec 10 2007 11:59:54 +00:00  c2800nm-advipservicesk9-mz.124-11.T4.bin
63881216 bytes total (11767808 bytes free)
Integarted Switch:
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SE              E4, RELEASE SOFTWARE (fc1)
Compiled Mon 16-Jul-07 03:24 by myl
Image text-base: 0x00003000, data-base: 0x01280000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)EZ, RELEASE SOFTWARE               (fc1)
S3-2811 uptime is 2 hours, 53 minutes
System restarted at 02:36:42 EST Wed May 10 2017
System image file is "flash:c3750-advipservicesk9-mz.122-25.SEE4/c3750-advipserv              icesk9-mz.122-25.SEE4.bin"
export@cisco.com.
cisco NME-16ES-1G-P (PowerPC405) processor (revision 3.0) with 118784K/12280K by              tes of memory.
Last reset from power-on
2 Virtual Ethernet interfaces
16 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:13:80:89:3F:00
Motherboard serial number       : FOC09193XJ3
Model revision number           : 3.0
Top Assembly Part Number        : 800-25009-01
Top Assembly Revision Number    : N/A
Version ID                      : V01
Hardware Board Revision Number  : 0x0F
Switch   Ports  Model              SW Version              SW Image
*    1   18     NME-16ES-1G-P      12.2(25)SEE4            C3750-ADVIPSERVICESK
Configuration register is 0xF
    2  -rwx        3096  Apr 22 2017 22:55:18 -05:00  multiple-fs
    3  drwx         128  Mar 24 2006 18:21:16 -05:00  crashinfo_ext
   19  -rwx        4870  Apr 22 2017 22:55:18 -05:00  config.text
    5  -rwx        2175  Feb 28 1993 19:41:42 -05:00  copy
  371  -rwx         105  Feb 28 1993 19:13:02 -05:00  info
   20  -rwx         944  Apr 10 2017 12:29:11 -05:00  vlan.dat
  377  drwx         192   Nov 1 2007 11:07:39 -05:00  c3750-advipservicesk9-mz.122-25.SEE4
   21  -rwx        4055  Apr 22 2017 22:55:18 -05:00  private-config.text
   10  drwx         768  Feb 28 1993 19:00:03 -05:00  crashinfo
32514048 bytes total (21595648 bytes free)
No crashinfo/crashlog file(s).  The "sh version" output shows the router could have a power feed issue or a power supply issue.
So what you saying is that it could be either the cable or integrated power supply since there is no power adapter like on smaller units just a regular cable? If that's the case I guess there is not much I can do.... maybe swap the switch module in to my second router since that's the only reason why I resurrected this router .... the other router has integrated WLC on the same spot but it's too old to use it and currently I'm using virtual WLC anyway. Thanks for quick respond :-)
PS: what abut actual "power strip" do you think that could be the failure point? It's just regular 5x power strip that you can get at regular store and currently there is at least 7 devices plug in to that strip
OK thanks I will definitely try that and report back, for now I will mark this as correct answer.
Just reporting back... it was the router itself probably power supply or something on the MB. End up swapping the switch-port to another 2811 router and 0 problems  for 2+ months
this sounds like a physical problem with either the external power source or cable, router power supply and circuit breaker, and router blower and fan, or inadequate ventilation or air circulation.
Here is a pretty good troubleshooting guide:
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/07_hw.html#wp1003699
I would love to troubleshoot but there is no warnings it just go dead... yes this particular router sits at the bottom of the rack but when I monitor my temperature it's all in normal. Either way I will look through that article.. thx
