router lab question
crystal91
Community Member
I have two router and two serial cable
Cisco 2620 + Smart Serial cable V.35 DTE(male)
Cisco 2501 + DB60 Serial cable V.35 DTE(male)
I want to connect two router by serial cable
Cisco 2620<-->Smart Serial Cable V.35 Male<-->V.35 Female-to-Female V.35<-->DB60 Serial cable V.35 Male<-->Cisco 2501
is this possible ?
If possible, what about V.35 Female-to-Female pin-out ?
thanks
shivlu jain
Level 9
Level 9
you need one female v.35 to db60 female
shivlu
I want to use existing serial cable by adding
V.35 female-to-female cable.
now, two routers're under trouble of clock problem.
how can I setup DCE-DTE V.35 female-to-female cable
thanks in advance
Pavel Bykov
Level 10
Level 10
You might have problem with DTE/DCE or clock. Try if it works.
Otherwise, you would be better off with this:
http://cgi.ebay.ca/NEW-Cisco-WIC-2T-Smart-Serial-DB60-back-to-back-Cable_W0QQitemZ310021707808QQcategoryZ3704QQcmdZViewItem
Smart serial to DB60.
