Router login issue
Nizamulla
  1. In my CISCO 540NCS Router not able to login with console pls help me
7 Replies 7
Richard Burts
We do not have much information to work with. Is this a new install? Or a previously installed device? If previously installed have you been able to login before now ?
Rick
johnlloyd_13
Level 9
Level 9
hi,
did you connect to console port (labelled "CON")?
try using other laptop and other terminal emulation app.
Yes connected but it's not working while i open putty in my laptop it shows
login username while i type anything it's take more time to show in front
of user name pls help me to clear the issue
hi,
change your console to 115200 baud rate.
other usual setting: 8 data bits, no parity, and 1 stop bit.
Hello
@Nizamulla wrote:
it shows login username while i type anything it's take more time to show in front
Is this a new router or is it active in production?
When it is slow at login prompt suggests the rtr is actively trying to authorize against a remote authentication server and its timeout is set to high.
Kind Regards
Paul
are you config aaa new model before assign any username/password locally ??
I agree that some details of how it is/was configured would be helpful.
Are you able to ping the device? If so is it possible to access it using telnet or ssh?
Rick
