Router QoS Configuration
JohnTylerPearce
Level 7
Level 7
Hey, How do you police traffic to a customer so they have forinstnace only 20Mbps with no bursting off of a specific interface.
police bps burst-normal burst-maxconform-action action exceed-action action violate-actionaction
I was wondering if you have to do all of that configuration or just what you need. My QoS skills aren't the best.
I'm a bit confused on how they all fit together, because I just want this client to only have 20 Mbps.
SOcchiogrosso
Level 4
Level 4
Here a decent link for configuring Policing
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpoli_ps1835_TSD_Products_Configuration_Guide_Chapter.html
Are you looking to police traffic or shape traffic? Policing drops excess traffic where-as shaping will queue it.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
SOcchiogrosso
Level 4
Level 4
Thanks for the information. I believe the rate-limit command will do what we want it to do.
From my understanding, you configure rate-limit by doing the following.
rate-limit bps normal-burst max-burst
So for instnace
rate-limit 20000000 10000000 5000000
So, this would allow him bursts of 1000000 and if there arnt enough tokens in the bucke it will borrow form the max burst.
I believe setting it that way will do the trick. I also, understand about the conform-action as well, I just didn't include it
in my configuration.
Correct, Rate-limiting will also do what your looking, however policing within the CBWFQ/LLQ model configuration is much more scalable if you have continue added to this configuration, just because you can break everything in class-maps and later on mark traffic for addition priorities in the same service-policy for when you addition QoS parameters later on.
But if your looking to rate-limit and nothing more you are good to go.
