router redundancy protocol
sureshchowdaryb
Community Member
Please tell me weather router redundancy protocol is available with cisco 1841. In not then from which model it starts.
rajatsetia
Level 5
Level 5
1841 does support HSRP . hope this will suffice your requirement.
rgds
rajat
Thanks Rajat, pls send me some doc or link in this regard.
Dear Rajat, One more thing if we see this feature in Cisco Product Advisor it shows that only Cisco 3800 series routers have these protocols. Pls help
Suresh.
this is what you can do to check
cisco feature navigator->
select hsrp as feature you cant to check-> continue ->
Select platform as 1841->
it will show you all the IOS for 1841 which have this feature available.
rgds
