Router Reset
cjtharpkc
I have 2 2611 routers with t1 dsu/csu. I am going to use them for my lab environment. They used to be in production here but now they have been replaced. I am running 12.3.1 How to I reset the config back to blank IOS
stomasko
Level 4
Level 4
Just do an erase start
then reload
When it asks you to save the config say NO.
Good luck
Steve
desai.jaideep
Level 5
Level 5
Try the command :
Router#erase startup-config
Router#reload
It will ask to save the config , where u should give no.
Another way of retaining the original config. is the config-register command....
Router(config)#config-register 0x2142
Router#reload
.....This will retain the NVRAM config, and boot in default config.
JD
