Router Rommon mode
gurkamal01
I am trying to work on a 7200 router and as soon as i turn it on it goes into Rommon mode
What coiuld be the possible problems with the routers and how can i fix it
I will aprecaite any response
Gursaran,
I would check it first.
Ok I did.
For Cisco 2600 router: It's quite the same.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
HTH,
Toshi
Is the same way for a low end router like the 2600
please advice.
Gursaran,
Ok I did.
HTH,
Toshi
