Showing results forĀ
Search instead forĀ
Did you mean:Ā
Router to load balance 2 servers With StaticIPs from different Subnets
MahendraHarkar
Hi Team,
I need help to choose a Router to handle my scenario.
My scenario is, i have 2 WebServers with 2 Static IPs from different SUBNETS.
I have a VIRTUAL IP mapped to my website www.abc.com.
Now i want to loadbalance my website url  https://www.abc.com  between my 2 WebServers.
I want to use SSL as well. I can get seperate SSL certificates for each Server and LoadBalancer/Router.
I mean, https://www.abc.com   should redirect to --> https://WebServer1-IPAddress   or
https://WebServer2-IPAddress .
The response should go back to the end client who gave the Request.
So, i need SSL configuration through-out the Request (loadbalancer and the WebServer also).
Please suggest an economical  Cisco Router which can handle this.
Also please explain the Layers to be used for LoadBalancing through-out the request.
Mahendra.
0 Replies 0
