Router Unable to Use Backup LSP in MPLS FRR
ans298
I have configured my MPLS enabled (OSPF overlayed, and using LDP for label distribution) R2 router's primary protected LSP as R2-R3-R4 and the backup LSP as R2-R4, which it should switch over to in case of any kind of node or link failure in the protected path.
Without a link failure, my packets are traversing the R2-R3-R4 path. But the link failure (which i triggered by doing a wire pull) is not switching the packets onto the backup link. I have tried to follow all instructions as per the documentation available at MPLS Traffic Engineering (TE)--Fast Reroute (FRR) Link and Node Protection - Cisco But am unable to figure out my mistake(s). Any insight would be appreciated. Thanks in advance.
Attached below are the configurations of R2 and R4, and the topology diagram.
R2 show run:
R1WB4#show run
Building configuration...
Current configuration : 2613 bytes
version 12.4
hostname R1WB4
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
mpls traffic-eng tunnels
mpls label protocol ldp
voice-card 0
archive
log config
  hidekeys
class-map match-any Test
class-map match-any WEB
match access-group 101
match  dscp ef
match access-group 102
policy-map QoS
class WEB
  set ip dscp ef
interface Loopback0
ip address 192.168.41.1 255.255.255.0
interface Tunnel1
ip unnumbered Loopback0
tunnel destination 192.168.42.1
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng path-option 1 explicit identifier 1
tunnel mpls traffic-eng fast-reroute bw-protect node-protect
no routing dynamic
interface Tunnel2
tunnel mpls traffic-eng path-option 2 explicit name avoid-protected-link
no routing dynamic
interface FastEthernet0/0
ip address 192.168.20.1 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
service-policy output QoS
interface FastEthernet0/1
ip address 192.168.30.2 255.255.255.0
duplex auto
speed auto
mpls traffic-eng backup-path Tunnel2
mpls ip
ip rsvp bandwidth 16
interface FastEthernet0/0/0
ip address 192.168.60.1 255.255.255.0
duplex auto
speed auto
mpls ip
router ospf 1
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
log-adjacency-changes
network 172.20.1.0 0.0.0.3 area 0
network 192.168.1.1 0.0.0.0 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.41.0 0.0.0.255 area 0
network 192.168.60.0 0.0.0.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
ip explicit-path identifier 1 enable
next-address 10.99.99.2
next-address 192.168.42.1
ip explicit-path name avoid-protected-link enable
mpls ldp router-id Loopback0 force
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
R1WB4#
R4 show run:
R2WB4#show run
Current configuration : 1991 bytes
version 12.4
hostname R2WB4
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
hidekeys
match dscp ef
policy-map QoS
class WEB
set ip dscp ef
interface Loopback0
ip address 192.168.42.1 255.255.255.0
ip address 192.168.50.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.40.1 255.255.255.0
duplex auto
speed auto
mpls ip
ip address 192.168.60.2 255.255.255.0
duplex auto
speed auto
mpls ip
router ospf 1
network 172.20.1.4 0.0.0.3 area 0
network 192.168.1.2 0.0.0.0 area 0
network 192.168.40.0 0.0.0.255 area 0
network 192.168.42.0 0.0.0.255 area 0
network 192.168.50.0 0.0.0.255 area 0
router isis 1
no ip forward-protocol nd
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R2WB4#
Hi anee su,
Some observations:
1) Configure the Loopbacks with a mask of /32 instead of /24.
R2 show run:
R1WB4#show run
interface Loopback0
ip address 192.168.41.1 255.255.255.255
R4 show run:
R2WB4#
interface Loopback0
ip address 192.168.42.1 255.255.255.255
2) Ensure all interfaces have 'ip rsvp bandwidth' configured. It is missing on R4's interface FastEthernet0/0/0.
R4 show run:
R2WB4#
3) Configure 'ip rsvp signalling hello' globally and on every interface on all Routers in the path.
For instance:
R2#
conf t
Once done check the outputs of 'show mpls traffic-eng fast-reroute database' before and during the test.
Let me know how it goes.
Regards.
keglass
Level 7
Level 7
I am moving your post to the Routing space for better visibility and access to feedback.
Routing
Thank you for participating in the communitiy.
Kelli Glass
Moderator for Cisco Customer Communities
Hi anee su,
Some observations:
R2 show run:
R1WB4#show run
interface Loopback0
R4 show run:
R2WB4#
interface Loopback0
R4 show run:
R2WB4#
For instance:
R2#
conf t
Regards.
Hi Hector, thanks for your observations! I have changed the masks for the loopback interfaces as you've suggested and setup rsvp hellos as well. After this I could see the packets being re-routed via the backup tunnel. I will share the output of 'show mpls traffic-eng fast-reroute database' command soon. Do share your thoughts on the same once I share it.
Sure anee su,
I'll be glad to help.
Regards.
