Router use for Ethernet hand off
oneboyblue22
Hello everyone,
we are trying to squeeze every ounce of life out of our hardware. Adding bandwidth to our network to accommodate social networking traffic. We are about to order a 200 meg Ethernet circuit with a T3 backup. We have two 3662s. My question: If I install a NM-2FEW2 card in one of them, will that serve as an Ethernet handoff? If not, is there a way to configure the 3662 as a handoff? What would I need to make that happen?
UPDATE: Understand that a 3662 with 100 meg ports probably won't work. What if we add gigabit adapter to 3662, or use a 7206vrx with gigabit adapter?
Richard Burts
I believe that there are several issues in what you are suggesting. First I am not sure that the 3662 can handle a 200 meg connection. Secondly to support a 200 meg connection it seems you would need a Gig interface. But the interfaces that you are dealing with are only 100 meg interfaces.
Rick
Rick
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Rick has already touched on, a 3660 series router doesn't have the performance to effectively support 200 Mbps.  For that kind of bandwidth, you would want something like a 3925E, or maybe a 3945.
