Router
ThulaniGoba7610
Hi everyone,
I quickly wanted to find out if it would be possible to buy an ISR4431/K9 and later install a PVDM4 on the Subs slot on the PRI Card? If you could please assist.
Thank you
Giuseppe Larosa
here is the procedure to follow to install a PVDM4 in an ISR4431 from Hardware installaiton guide for ISR 4000
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/FRUs_Modules.html#48696
Warning: you may need appropriate license/feature set  to be able to use the module.
see the voice datasheet
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-728308.html
Hope to help
Giuseppe
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/FRUs_Modules.html#81118
                  I would then presume this would work.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
