routers Module
alsayed
i need to know if 2620 series routers can Support the FIBER Port if yes what is the name of the Port.the senario is:i'll implement 2 (2620 routers)geteway redundancy for my site each one of the routers connected to 2 distributon(2 4503 series)the distance betweeen the first router to the first distribution is 450M.the second router to the second distribution is 1000M.the cabling in the Lan is Fiber Optic.
10xs
Ali
Roberto Salazar
Level 8
Level 8
NM-16ESW-1GIG have a bundled GIG port and it's fiber. for the connections you'll need LX/LH GBIC with SMF fibert type. The NM requires at least 12.2(8)T or 12.3(1) Mainline. This is the only moduel that has gig that is supported in 26xx platform
Please rate helpful posts.
10xs for ur reply.but what about the redundancy between the 2 routers(hsrp).these 2 routers connected to the HQ.
