Routes issue in ipsec tunnel
lakhwaraa
I have following configuration. My tunnel is up but i cant send routes since yesterday. I have done nothing to the original configuration. My router is not advertising my routes
interface Tunnel1
ip address 100.200.10.5 255.255.255.0
no ip redirects
ip mtu 1390
ip authentication mode eigrp 10 md5
ip authentication key-chain eigrp 10 eigrp_keys
ip hold-time eigrp 10 60
ip nhrp authentication deast
ip nhrp map multicast 50.217.30.110
ip nhrp map 100.200.10.12 50.217.30.110
ip nhrp map multicast 51.230.159.19
ip nhrp map 100.200.10.254 51.230.159.19
ip nhrp network-id 2
ip nhrp holdtime 60
ip nhrp nhs 100.200.10.12
ip nhrp nhs 100.200.10.254
zone-member security vpn
tunnel source GigabitEthernet0
tunnel mode gre multipoint
tunnel key 121
tunnel protection ipsec profile FL-DE-SWITC
router eigrp 10
network 100.200.10.0 0.0.0.255
network 172.17.30.0 0.0.0.255
passive-interface Vlan10
eigrp stub connected
router eigrp 2
network 10.2.2.0 0.0.0.255
network 172.17.0.0
passive-interface FastEthernet8
interface GigabitEthernet0
mac-address e02f.6d0d.2123
ip address 122.31.15.11 255.255.255.248
ip nat outside
ip virtual-reassembly in
zone-member security outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip address 172.17.30.254 255.255.0.0
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
zone-member security inside
ip tcp adjust-mss 1450
sh dmvpn
Interface: Tunnel1, IPv4 NHRP Details
Type:Spoke, NHRP Peers:2,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 50.217.30.110 100.200.10.12 UP 10:27:49 S
1 51.230.159.19 100.200.10.254 UP 1d12h S
sh crypto session
Interface: Tunnel1
Session status: UP-ACTIVE
Peer: 51.230.159.19 port 500
Session ID: 0
IKEv1 SA: local 122.31.15.11/500 remote 51.230.159.19/500 Active
IPSEC FLOW: permit 47 host 122.31.15.11 host 51.230.159.19
Active SAs: 2, origin: crypto map
Sh ip route
Gateway of last resort is 122.31.15.121 to network 0.0.0.0
S* 0.0.0.0/0 [3/0] via 122.31.15.11
1.0.0.0/32 is subnetted, 1 subnets
S 1.1.1.1 [1/0] via 122.31.15.11
8.0.0.0/32 is subnetted, 1 subnets
S 8.8.8.8 [1/0] via 122.31.15.11
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 100.200.10.0/24 is directly connected, Tunnel1
L 100.200.10.5/32 is directly connected, Tunnel1
S 10.20.1.0/24 [1/0] via 100.200.10.254
119.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 122.31.15.11/29 is directly connected, GigabitEthernet0
L 122.31.15.12/32 is directly connected, GigabitEthernet0
L 122.31.15.13 is directly connected, GigabitEthernet0
L 122.31.15.14/32 is directly connected, GigabitEthernet0
172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.17.0.0/16 is directly connected, Vlan10
L 172.17.30.254/32 is directly connected, Vlan10
172.20.0.0/24 is subnetted, 1 subnets
S 172.20.17.0 [1/0] via 100.200.10.12
S 192.168.20.0/24 [1/0] via 100.200.10.249
try and remove and reapply the EIGRP authentication. First, turn on debugging:
Router#debug eigrp packets terse
Then, remove and reapply the key chain.
Router#conf t
Router(config)interface Tunnel1
Router(config-if)#no ip authentication key-chain eigrp 10 eigrp_keys
Router(config-if)#ip authentication key-chain eigrp 10 eigrp_keys
Post the debug output you see.
13 Replies 13
no ip next-hop self eigrp x
no ip split-horizon eigrp x
you need both this command in Hub tunnel
Already has this command in hub
interface Tunnel1
bandwidth 1602
ip address 100.200.10.254 255.255.255.0
no ip redirects
ip mtu 1390
no ip next-hop-self eigrp 10
no ip split-horizon eigrp 10
ip nhrp map multicast dynamic
ip nhrp registration no-unique
ip tcp adjust-mss 1350
delay 300
tunnel source GigabitEthernet0/1
tunnel key 121
tunnel protection ipsec profile FL-DE-SWITC shared
the configuration suddenly died even no body changed it.
OK,
1-tunnel UP not meaning that is health,
please can you config
if-state nhrp
in spoke and check the tunnel still UP or down ?
2-network 172.17.30.0 0.0.0.255 <<-interface Vlan10 ip address 172.17.30.254 255.255.0.0
please can match the subnet mask f VLAN10 and what you config under EIGRP
3- I dont try before but I will check by lab the config of two EIGRP process and advertise same IP. (I will update you soon).
1. Tunnel is still active
Interface: Tunnel1
2.
IP : Vlan10 172.17.30.254
router eigrp 10
all configuration is ok
I run lab and It OK for me,
can you share the zone security config ?
class-map type inspect match-any inside-to-vpn
match access-group name ACL-INSIDE-TO-VPN
class-map type inspect match-any vpn-to-inside
match access-group name ACL-VPN-TO-INSIDE
class-map type inspect match-any inside-to-outside
match access-group name ACL-INSIDE-TO-OUTSIDE
class-map type inspect match-any outside-to-self
match access-group name ACL-outside-TO-self
class-map type inspect match-any self-to-outside
match access-group name ACL-self-TO-outside
class-map type inspect match-any outside-to-inside
policy-map type inspect Policy-inside-to-outside
class type inspect inside-to-outside
inspect
class class-default
drop
policy-map type inspect Policy-outside-to-inside
class type inspect outside-to-inside
inspect
class class-default
drop
policy-map type inspect Policy-outside-to-self
class type inspect outside-to-self
inspect
class class-default
drop
policy-map type inspect Policy-inside-to-vpn
class type inspect inside-to-vpn
inspect
class class-default
drop
policy-map type inspect Policy-vpn-to-inside
class type inspect vpn-to-inside
inspect
class class-default
drop
policy-map type inspect Policy-self-to-outside
class type inspect self-to-outside
inspect
class class-default
drop
zone security inside
zone security outside
zone security vpn
zone-pair security inside-to-outside source inside destination outside
service-policy type inspect Policy-inside-to-outside
zone-pair security inside-to-vpn source inside destination vpn
service-policy type inspect Policy-inside-to-vpn
zone-pair security vpn-to-inside source vpn destination inside
service-policy type inspect Policy-vpn-to-inside
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect Policy-outside-to-inside
zone-pair security vpn-to-outside source vpn destination outside
zone-pair security outside-to-vpn source outside destination vpn
ip route 1.1.1.1 255.255.255.255 122.31.15.121
ip route 8.8.8.8 255.255.255.255 122.31.15.121
ip access-list extended ACL-INSIDE-TO-OUTSIDE
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended ACL-INSIDE-TO-VPN
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended ACL-OUTSIDE-TO-INSIDE
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended ACL-VPN-TO-INSIDE
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended ACL-outside-TO-self
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended ACL-self-TO-outside
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended NAT
permit ip any any
permit gre any any
permit icmp any any
ip access-list extended webserver
permit ip any any
permit gre any any
permit icmp any any
I do same zone security config and It OK,
still one thing
you mention that the eigrp stop advertise the route,
I see you use key-chain for auth can I see config ??
can you share
show ip eigrp
neighbor ?
show ip eigrp neighbor
EIGRP-IPv4 Neighbors for AS(10)
EIGRP-IPv4 Neighbors for AS(2)
crypto isakmp policy 100
encr aes
authentication pre-share
group 2
crypto isakmp key hehs@jj address 0.0.0.0
crypto isakmp keepalive 60
crypto ipsec transform-set FL-DE-SWITC esp-aes esp-sha-hmac
mode transport
crypto ipsec profile Removed
set transform-set FL-DE-SWITC
this key I talk about, we already check that tunnel is UP and health.
Router#conf t
I have done this configuration by installing a secondary internet source and creating tunnel 2 with same configuration.
it works
but tunnel 1 has some routing issue. how to check routing issue
my tunnel is up thanks to you. But now there is one more problem
i can ping my hub router interface (10.20.1.11) from my spoke using tunnel but my computer can not ping it. why
Hello
@lakhwaraa wrote:
interface Tunnel1
 I have done this configuration by installing a secondary internet source and creating tunnel 2 with same configuration.,
it works, but tunnel 1 has some routing issue. how to check routing issue
By the sounds of it you have a dual DMVPN hub, if so you need to implement some resiliency and conditional routing
Append the following on the spoke (NHC) and test..
int tun 1
ip nhrp nhs 100.200.10.12 cluster 1
ip nhrp nhs 100.200.10.254 priority 255 cluster 1
ip nhrp nhs cluster 1 max-connections 1
ip nhrp nhs fallback 25
Kind Regards
Paul
