Routing Between Different VLANS and Subnets
thisishusamm
Hope you are doing well.
I have the following devices in my network
- 2 * Cisco Switch 3560
- Cisco Switch 3750 MLS
every Cisco Switch 3560 have different Vlans and subnets, first Cisco Switch have:
GIS_SW
VLAN 30
Network: 30.1.1.0 255.255.255.0
VLAN 40
Network: 40.1.1.0 255.255.255.0
VLAN 50
Network: 50.1.1.0 255.255.255.0
Second Switch:
Al_Abass_1_SW
VLAN 60
Network: 60.1.1.0 255.255.255.0
VLAN 70
Network: 70.1.1.0 255.255.255.0
VLAN 80
Network: 80.1.1.0 255.255.255.0
I want to routing between VLANS in Middel switch MLS. How can I do that?
10 Replies 10
all your SVI (Vlan interfaces) have to be configured on the middle switch. You cannot configure any other Vlan interfaces (other than the Vlan interface used for management) on the other switches.
Is this a Packet Tracer project ? If so, post the zipped Packet Tracer project (.pkt) file. If not, post the full running configs of all three switches.
thanks for your reply Dear,
No, it's just diagram by packet tracer. the main question is how can I do the routing in the middle switch?
Hello @thisishusamm ,
if you have real switches you can do the following :
enable ip routing on the two 3560 access switches.
Create a VLAN 90 for L3 communication between GIS_SW and C3750 using a new subnet like 10.10.90.0/24
vlan 90
exit
Configure SVI interface VLAN 90 on GIS_SW
interface vlan 90
desc to C3750 L3
ip address 10.10.90.2 255.255.255.0
no shut
interface between GIS_SW and C3750 can be in access mode vlan 90
interface gi1/0/x
desc to C3750:
switchport
switchport mode access
switchport access vlan 90
The same you do on C3750 switch
create vlan 90 at layer 2
vlan 90
exit
interface vlan 90
desc L3 to GIS_SW
ip address 10.10.90.1 255.255.255.0
on GIS_SW
ip route 0.0.0.0 0.0.0.0 10.10.90.1
on C3750
ip route 30.1.1.0 255.255.255.0 10.10.90.2
ip route 40.1.1.0 255.255.255.0 10.10.90.2
ip route 50.1.1.0 255.255.255.0 10.10.90.2
Create a VLAN like 100 for L3 communication between middle C3750 and right switch AI_Abass_1_SW
enable ip routing on AI_Abass_1_SW
create vlan 100 at layer 2
vlan 100
exit
configure vlan 100 SVI interface
interface vlan 100
desc L3 link to C3750
ip address 10.10.100.2 255.255.255.0
no shut
configure physical port to C3750 as access in vlan 100
int gi1/0/y
desc to C3750
switchport
switchport access vlan 100
Do the same things on C3750
create vlan 100 at layr 2
vlan 100
exit
configure interface SVI vlan 100
interface vlan 100
desc link L3 to AI_Abass_1_SW
ip address 10.10.100.1 255.255.255.0
no shut
interface gi1/0/z
desc to AI_Abass_1_SW:gi1/0/y
switchport
on AI_Abass_1_SW
ip routing
ip route 0.0.0.0 0.0.0.0 10.10.100.1
on C3750 side you add
ip route 60.1.1.0 255.255.255.0 10.10.100.2
ip route 70.1.1.0 255.255.255.0 10.10.100.2
ip route 80.1.1.0 255.255.255.0 10.10.100.2
There are many other ways to do the routing you can use a dynamic routing like OSPF. Here I have presented the simplest solution with static routes using default routes from acces layer switches to the C3750 (otherwise I should have configured specific static routes for remote subnets on access layer switches too)
Hope to help
Giuseppe
Thanks for your reply dear.
Be informed I want GRE_SW and Al_Abass_SW as L2 switches. I Don't want to do routing in that switches.
--> I want to routing between VLANS in Middel switch MLS. How can I do that?
Do you want ONLY the middle switch to be a layer 3 switch (and do the inter-Vlan routing), or are all three switches supposed to be layer 3 switches (and do routing as well) ?
Hello Dear,
want ONLY the middle switch to be a layer 3 switch (and do the inter-Vlan routing).
Thanks in advanced.
in that case, make sure only the middle switch has 'ip routing' enabled. Configure the links between all three switches as trunks, and configure the Vlan interfaces on the middle switch:
GIS_SW --> Trunk --> Al_Abass_2_SW --> Trunk Al_ABASS_1_SW
interface Vlan 30
ip address 30.1.1.1 255.255.255.0
interface Vlan 40
ip address 40.1.1.1 255.255.255.0
interface Vlan 50
ip address 50.1.1.1 255.255.255.0
interface Vlan 60
ip address 60.1.1.1 255.255.255.0
interface Vlan 70
ip address 70.1.1.1 255.255.255.0
interface Vlan 80
ip address 80.1.1.1 255.255.255.0
Thanks for your reply,
Without any routing command in the middle switch?
as stated, the middle switch needs to have 'ip routing' enabled:
Al_Abass_2_SW#conf t
Al_Abass_2_SW(config)#ip routing
Hello
What you are showing is a routed access-layer network which is a valid design that wont require spanning- tree or trunks
To establish vlan connectivity between the two switches one possible approach would be you enable Ip routing on the two end switches using an igp such as ospf or eigrp (if they are both cisco)
connecting them via a shared routed subnet which will the  allow you to advertise each switch’s  vlans to each other
The middle switch will provide only layer 2 interconnection between the two routed switch’s in a non routable vlan of your choosing.
Kind Regards
Paul
