Routing between the same IP remote segments
remi-reszka
Level 6
Level 6
Hi all,
We have a remote site that needs to use the same IP address scheme on one of their segments that is on the main site. I know I can do such routing with VRF over MPLS, VPLS, pseudowires but the problem is that our ISP does not support that.
Is it possible to do it with NAT or VPN technologies?
Thanks for any suggestions.
Remi
darren.g
Level 10
Level 10
remi-reszka wrote:
Hi all,
Remi
NAT would be the answer, at one end or the other of the link.
At the remote site, you could NAT the whole subnet to one which doesn't exist at your main office, so that as far as the main office is concerned, the remote office is on a completely different subnet range.
You should be able to do one-to-one NAT, depending on your router - turn, say, 192.168.1.200 on the inside to 192.168.40.200 on the outside. Then, at your main office, just have the routing table point to 192.168.40.0 instead of 192.168.1.0.
Cheers.
milan.kulik
Level 11
Level 11
this might help you with NATing in your case:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
You just need to be sure all your applications are NAT-capable.
And also you need your provider to route the subnet you are using for NATing to the proper site.
HTH,
Milan
