Routing Compilation using Static Routing, BGP, and OSPF
putra.research
Hi, I want to make routing in each area using different type of routing in Cisco Packet Tracer. Routers in Red area will use Static Routing, Blue area use BGP, and Green area use OSPF. And I have a few question. The first one, I have a problem when I configure the Static Routing in Router 0. Is there any solution for that? The second question is, how do I connect all the router so router in each area can connected even though they have a different routing configuration? I hope there are any solution. Thank you for helping
PS: I attach my Cisco Packet Tracer file below
You can see static routes with this command actually.
Router#sh ip route static
S 192.168.20.0/24 [1/0] via 192.168.10.1
S 192.168.30.0/24 [1/0] via 192.168.10.1
S* 0.0.0.0/0 [1/0] via 192.168.10.1
R0 does not show because they are directly connected.
7 Replies 7
 I am sharing  a working file. You can use for you study. And below, some explanation about what I did.
On R0, you can add a default route like:
0.0.0.0 0.0.0.0 192.168.30.2 (everything else, send to .2)
And then, you add the static route for specifics, just like you did
R1 need on default route pointing to R0
0.0.0.0 0.0.0.0 192.168.10.1
R2 need one default route poinintg to R0
0.0.0.0 0.0.0.0 192.168.20.1
R8 need to have static routes pointing to 192.168.30.1 for all networks
192.168.10.0
192.168.20.0
192.168.30.0
R8 - Redistribute static
router bgp 100
bgp log-neighbor-changes
no synchronization
neighbor 192.168.70.2 remote-as 200
network 192.168.70.0
network 192.168.30.0
redistribute static
R7: Redistribute ospf into BGP and BGP into OSPF
router ospf 1
log-adjacency-changes
redistribute bgp 200
network 192.168.40.0 0.0.0.255 area 0
router bgp 200
no synchronization
neighbor 192.168.70.1 remote-as 100
redistribute ospf 1
Anyway thank you so much for your help, but I think I'm still have a problem with static routing in Router 0. I've configure the Static Routing like you have tell, but when I check using command show ip route in CLI, it doesn't show the Static Routing in the IP table. As long as I know (CMIIW) if the routing success it will show in IP Table. Did I make a mistake when configuring the static routing?
Only default route will be shown:
C 192.168.10.0/24 is directly connected, Serial2/0
C 192.168.20.0/24 is directly connected, Serial3/0
C 192.168.30.0/24 is directly connected, Serial6/0
S* 0.0.0.0/0 [1/0] via 192.168.30.2
The static route will not.
Using the file I sent, I could sucessfuly ping from one end to another, so, routing problem must not have.
Ah I see. Thank you for the explanation. But I'm sorry, can you send again your file? 'cause I think I can't find your file from your reply above
Yes there is problem
you config static route to subnet already connect to your router ???
the static route must include
Subnet in other Router & outlet of your router to that router
or
Subnet in other Router & next-hop of that router
Hello
  1. external BGP rtrs - advertise a default route towards each site bgp rtr.
    <router bgp x
    neighbor x.x.x.x default-information originate
  2. Static route site bgp rtr -   redistribute all static routes into bgp that point towards each static router,
    <router bgp x
    redistribute static
  3. Ospf site bgp rtr -   Redistribute ospf into bgp
    < router bgp xx
    redistribute ospf x match external 1 external 2
Kind Regards
Paul
