Routing from port connected subnets failing
gregggertsner1
Issue
I have several ports configured with IP.  Hosts in these subnets can not connect to a remote device.  However, devices directly attached can communicate to the remote device.
E.G.
Port 6/6 is configured for connections to the 172.20.61.x Network
Devices traceroute to remote network 172.20.118.x stop at 172.20.61.1 (the core switch)
tracert 172.20.118.156
Tracing route to 172.20.118.156 over a maximum of 30 hops
1  < 1ms      <1ms        <1ms  172.20.61.1
2     *             *               *       Request timed out
Devices connected directly to the core switch traceroute successfully
traceroute 172.20.118.56
trying to get source for 172.20.118.56
source should be 172.20.21.4
traceroute to 172.20.118.56 (172.20.118.56) from 172.20.21.4 (172.20.21.4), 30 hops max
outgoing MTU = 1500
1 172.20.21.2 (172.20.21.2) 4 ms 3 ms 1 ms
2 172.20.21.225 (172.20.21.225) 2 ms 6 ms 1 ms
3 172.20.21.225 (172.20.21.225) 1 ms
fragmentation required, trying new MTU = 1492
3 * 2 ms
fragmentation required, trying new MTU = 1480
3 * 1 ms
fragmentation required, trying new MTU = 1472
3 10.4.4.2 (10.4.4.2) 4 ms 3 ms 3 ms
4 172.20.118.56 (172.20.118.56) 4 ms 4 ms 4 ms
Traceroutes from the remote server to direct attached devices (172.20.21.x) obviously works
Traceroutes to one of the subnets drop at the NGN Router
Network Diagram
Routing Table
The routing table on the core does show all subnets in question correctly
4506-1#sho ip route
Gateway of last resort is 172.20.250.1 to network 0.0.0.0
O E2 192.168.106.0/24 [110/20] via 172.20.250.1, 01:06:00, Vlan250
137.200.0.0/24 is subnetted, 2 subnets
S 137.200.84.0 [1/0] via 172.20.250.1
S 137.200.35.0 [1/0] via 172.20.250.1
O E2 192.168.104.0/24 [110/20] via 172.20.250.1, 01:06:00, Vlan250
172.20.0.0/16 is variably subnetted, 26 subnets, 3 masks
C 172.20.48.128/25 is directly connected, GigabitEthernet1/1
O IA 172.20.45.128/26 [110/13] via 172.20.250.1, 01:06:00, Vlan250
O 172.20.248.0/24 [110/11] via 172.20.250.1, 01:06:00, Vlan250
C 172.20.250.0/24 is directly connected, Vlan250
C 172.20.61.0/24 is directly connected, GigabitEthernet6/6
S 172.20.62.0/24 [1/0] via 172.20.21.225
C 172.20.48.0/25 is directly connected, GigabitEthernet6/4
C 172.20.49.0/24 is directly connected, GigabitEthernet6/5
C 172.20.45.0/25 is directly connected, GigabitEthernet6/1
C 172.20.46.0/24 is directly connected, GigabitEthernet6/2
C 172.20.47.0/24 is directly connected, GigabitEthernet6/3
S 172.20.30.0/24 [1/0] via 172.20.21.225
S 172.20.16.0/24 [1/0] via 172.20.250.1
C 172.20.21.0/24 is directly connected, Vlan1
O E2 172.20.2.0/24 [110/20] via 172.20.250.1, 01:06:00, Vlan250
S 172.20.120.0/24 [1/0] via 172.20.21.225
S 172.20.113.0/24 [1/0] via 172.20.21.225
S 172.20.114.0/24 [1/0] via 172.20.21.225
O IA 172.20.115.0/24 [110/13] via 172.20.250.1, 01:06:00, Vlan250
S 172.20.116.0/24 [1/0] via 172.20.21.225
S 172.20.117.0/24 [1/0] via 172.20.21.225
S 172.20.118.0/24 [1/0] via 172.20.21.225
S 172.20.95.0/24 [1/0] via 172.20.21.225
S 172.20.81.0/24 [1/0] via 172.20.21.225
C 172.20.78.0/24 is directly connected, Vlan78
C 172.20.66.0/24 is directly connected, Vlan66
172.23.0.0/32 is subnetted, 3 subnets
S 172.23.152.43 [1/0] via 10.21.112.11
S 172.23.152.42 [1/0] via 10.21.112.11
S 172.23.132.14 [1/0] via 10.21.112.14
172.25.0.0/24 is subnetted, 10 subnets
S 172.25.50.0 [1/0] via 172.20.21.225
S 172.25.40.0 [1/0] via 172.20.21.225
[1/0] via 172.20.21.255
S 172.25.20.0 [1/0] via 172.20.21.225
S 172.25.23.0 [1/0] via 172.20.21.225
S 172.25.19.0 [1/0] via 172.20.21.225
S 172.25.29.0 [1/0] via 172.20.21.225
S 172.25.30.0 [1/0] via 172.20.21.255
S 172.25.26.0 [1/0] via 172.20.21.225
S 172.25.10.0 [1/0] via 172.20.21.225
S 172.25.100.0 [1/0] via 172.20.21.225
172.24.0.0/32 is subnetted, 1 subnets
S 172.24.4.236 [1/0] via 10.21.112.14
192.10.200.0/32 is subnetted, 2 subnets
S 192.10.200.117 [1/0] via 172.20.250.1
[1/0] via 172.20.21.254
S 192.10.200.134 [1/0] via 172.20.21.254
10.0.0.0/8 is variably subnetted, 8 subnets, 4 masks
O IA 10.253.253.0/30 [110/1011] via 172.20.250.1, 01:06:02, Vlan250
O IA 10.252.252.0/28 [110/12] via 172.20.250.1, 01:06:02, Vlan250
S 10.252.252.0/24 [1/0] via 172.20.21.225
S 10.30.30.0/24 [1/0] via 172.20.250.1
C 10.1.0.0/20 is directly connected, FastEthernet4/47
S 10.20.60.0/24 [1/0] via 172.20.250.1
O 10.21.112.0/24 [110/11] via 172.20.250.1, 01:06:02, Vlan250
O 10.21.111.0/24 [110/11] via 172.20.250.1, 01:06:02, Vlan250
192.10.202.0/32 is subnetted, 2 subnets
S 192.10.202.60 [1/0] via 172.20.21.254
S 192.10.202.62 [1/0] via 172.20.21.254
S 192.168.254.0/24 [1/0] via 172.20.21.225
O E2 192.168.103.0/24 [110/20] via 172.20.250.1, 01:06:02, Vlan250
O*E2 0.0.0.0/0 [110/10] via 172.20.250.1, 01:06:02, Vlan250
The default gateway also has these routes defined
Current Config, Edited
Current configuration : 11736 bytes
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
power dc input 2500
interface GigabitEthernet1/1
 description subnet 60 sw closet7-1
 no switchport
 ip address 172.20.48.129 255.255.255.128
 ip helper-address 172.20.21.235
interface GigabitEthernet1/2
interface FastEthernet2/38
 description Temp FCITY Network
 switchport access vlan 78
interface FastEthernet2/39
interface FastEthernet2/40
 description Temp CCITY Network
 switchport access vlan 66
interface FastEthernet4/1
 description Fortigate-01-port1
 switchport access vlan 250
interface FastEthernet4/2
 description Fortigate-01-port2
interface FastEthernet4/3
 description Fortigate-01-port5
 switchport access vlan 248
interface FastEthernet4/18
 description Smartnet-switch-ge0/2
 switchport mode trunk
interface FastEthernet4/47
 description Dxx Subnet 10.1.10.x
 no switchport
 ip address 10.1.10.1 255.255.240.0
interface FastEthernet4/48
interface FastEthernet5/1
 description Fortigate-02-port1
interface FastEthernet5/2
 description Fortigate-02-port2
interface FastEthernet5/3
 description Fortigate-02-port5
interface FastEthernet5/7
 description link router 172.20.21.1
interface GigabitEthernet6/1
 description subnet 45 cw closet 1-1
 no switchport
 ip address 172.20.45.1 255.255.255.128
interface GigabitEthernet6/2
 description subnet 46 sw closet2-1
 no switchport
 ip address 172.20.46.1 255.255.255.0
interface GigabitEthernet6/3
 description subnet 47 sw closet3-1
 no switchport
 ip address 172.20.47.1 255.255.255.0
interface GigabitEthernet6/4
 description subnet 48 sw closet4-1
 no switchport
 ip address 172.20.48.1 255.255.255.128
interface GigabitEthernet6/5
 description subnet 49 sw closet5-1
 no switchport
 ip address 172.20.49.1 255.255.255.0
interface GigabitEthernet6/6
 description subnet 61 sw closet6-1
 no switchport
 ip address 172.20.61.1 255.255.255.0
interface Vlan1
 ip address 172.20.21.11 255.255.255.0 secondary
 ip address 172.20.21.2 255.255.255.0
interface Vlan66
 ip address 172.20.66.1 255.255.255.0
interface Vlan78
 ip address 172.20.78.1 255.255.255.0
interface Vlan248
 description MPLS
 no ip address
interface Vlan250
 description FIREWALL
 ip address 172.20.250.2 255.255.255.0
interface Vlan251
 description WSZ
 no ip address
interface Vlan252
 description DMZ
 no ip address
router ospf 1
 log-adjacency-changes
 area 0 range 172.0.0.0 255.0.0.0
 network 10.21.111.0 0.0.0.255 area 0
 network 172.18.4.0 0.0.0.255 area 0
 network 172.20.21.0 0.0.0.255 area 0
 network 172.20.45.0 0.0.0.255 area 0
 network 172.20.46.0 0.0.0.255 area 0
 network 172.20.47.0 0.0.0.255 area 0
 network 172.20.48.0 0.0.0.255 area 0
 network 172.20.49.0 0.0.0.255 area 0
 network 172.20.60.0 0.0.0.255 area 0
 network 172.20.61.0 0.0.0.255 area 0
 network 172.20.66.0 0.0.0.255 area 0
 network 172.20.78.0 0.0.0.255 area 0
 network 172.20.250.0 0.0.0.255 area 0
 distribute-list 10 in
ip default-gateway 172.20.250.1
ip classless
ip route 10.20.60.0 255.255.255.0 172.20.250.1
ip route 10.30.30.0 255.255.255.0 172.20.250.1
ip route 10.252.252.0 255.255.255.0 172.20.21.225
ip route 137.200.35.0 255.255.255.0 172.20.250.1
ip route 137.200.84.0 255.255.255.0 172.20.250.1
ip route 172.20.16.0 255.255.255.0 172.20.250.1
ip route 172.20.30.0 255.255.255.0 172.20.21.225
ip route 172.20.62.0 255.255.255.0 172.20.21.225
ip route 172.20.81.0 255.255.255.0 172.20.21.225
ip route 172.20.95.0 255.255.255.0 172.20.21.225
ip route 172.20.113.0 255.255.255.0 172.20.21.225
ip route 172.20.114.0 255.255.255.0 172.20.21.225
ip route 172.20.116.0 255.255.255.0 172.20.21.225
ip route 172.20.117.0 255.255.255.0 172.20.21.225
ip route 172.20.118.0 255.255.255.0 172.20.21.225
ip route 172.20.120.0 255.255.255.0 172.20.21.225
ip route 172.23.132.14 255.255.255.255 10.21.112.14
ip route 172.23.152.42 255.255.255.255 10.21.112.11
ip route 172.23.152.43 255.255.255.255 10.21.112.11
ip route 172.24.4.236 255.255.255.255 10.21.112.14
ip route 172.25.10.0 255.255.255.0 172.20.21.225
ip route 172.25.19.0 255.255.255.0 172.20.21.225
ip route 172.25.20.0 255.255.255.0 172.20.21.225
ip route 172.25.23.0 255.255.255.0 172.20.21.225
ip route 172.25.26.0 255.255.255.0 172.20.21.225
ip route 172.25.29.0 255.255.255.0 172.20.21.225
ip route 172.25.30.0 255.255.255.0 172.20.21.255
ip route 172.25.30.0 255.255.255.0 172.20.21.225
ip route 172.25.40.0 255.255.255.0 172.20.21.225
ip route 172.25.40.0 255.255.255.0 172.20.21.255
ip route 172.25.50.0 255.255.255.0 172.20.21.225
ip route 172.25.100.0 255.255.255.0 172.20.21.225
ip route 192.10.200.117 255.255.255.255 172.20.250.1
ip route 192.10.200.117 255.255.255.255 172.20.21.254
ip route 192.10.200.134 255.255.255.255 172.20.21.254
ip route 192.10.202.60 255.255.255.255 172.20.21.254
ip route 192.10.202.62 255.255.255.255 172.20.21.254
ip route 192.168.106.0 255.255.255.0 172.18.4.1
ip route 192.168.254.0 255.255.255.0 172.20.21.225
access-list 10 permit any
Any thoughts or suggestions would be appreciated
Jon Marshall
The NGN router does not have a route for 172.20.61.0/24.
Jon
