Routing Instance and logical system in Cisco ASR.
AKK
Hi All,
I need help on below.
1) What is equal of Juniper MX series router's Routing Instance and logical system in Cisco ASR and how to configure the same.
2) Can we have multiple next-hop with tracking in Route-map for PBR.
AKK
Hello
@AKK wrote:
Hi All,
Possisble Virtual Routing Instance ( VRF)
@AKK wrote:Can we have multiple next-hop with tracking in Route-map for PBR.
Yes you can have conditional NHT with policy based routing (PBR)
Kind Regards
Paul
Giuseppe Larosa
Hello @AKK ,
on ASR 1000 Cisco VRF is the equivalent of a routing instance of type virtual router in Juniper JUNOS. Logical systems means a form of virtualization of the device that has no equivalent in Cisco world.   Just to make an example ASR 9000 or other carrier grade CSR nodes running IOS XR can be partitioned in multiple logical nodes, but it is more hardware related in comparison to Juniper logical systems you assign linecards or group of ports to a logical node.
2) as explained by @paul driver  you can trace the state of multiple next-hops in PBR
Hope to help
Giuseppe
