Cisco Router Failover between Static Route and BGP Link
premvishwakarma
I have a router with two links.
One is BGP link and another is Static Route.
I want to configure both ink as failover, where static route will be primary and if static route failed it should shift to BGP link. Once static route up again it shoud
It automatically shift,
The static have ad 1 and bgp have ad 20,
So router always prefer lowest ad which is static, when it fialed
Via
1- egress interface is down
2- ip sla track is down
Then static route will remove from rib and router will use bgp.
Via
premvishwakarma
This works for me. Thanks for your support !
