Routing Interview Questions
nidhin.chandran
Hi All,
Can you please any one help me in below question.
How many routers can connect back to back .(for example: i have 250  Routers which is connected one to second , second to third , third to fourth etc.
PC-A which is connected to first Router and PC B connected to Last router(250th Router).
Possible to ping from PC-A to PC-B if i am using static route otherwise dynamic protocols like OSPF & EIGRP.
Please reply............
Ruben Cocheno
Don´t forget maximum TTL is 255, so you can have only 255 hops away, now do the math
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
Ruben Cocheno
