routing issue
TECH-JEFF
Hi, let me give a brief scenario of my issue. our existing infra is from a Cisco ASA 5520 which has the following:
Port0: local IP 192.168.120.254
Port1: WAN1 203.208.x.x
Port2: WAN2 208.203.x.x
Port3: DMZ 172.16..x.x
Below this firewall is a Cisco 3750 L3 switch, the switch does the DHCP, and there's only 1 IP route going to the firewall, that is
ip route 0.0.0.0 0.0.0.0 192.168.120.254
no other settings except dhcp and VLON's
So we decided to use another firewall, FW2 and use WAN2 so as not to disrupt the operation of the office using WAN1. Since the L3 switch has a lot of ports, we took a spare port on the L3 and connect this on the second FW2. I setup a separate IP route but Im not sure if this will work.
ip route 192.168.90.0 255.255.255.0 192.168.160.5 (this is the local interface of the FW2)
but for some reason, the pc connected where the new FW2 is able to get an ip address from the L3 but it cannot go thru the internet. It cant even ping the new local interface of FW2(192.168.160.5), did I add the correct route? As of the moment, my focus is not to get to the internet but instead able to ping the new FW2 local interface(192.168.160.5)
Jeff
Jefferson Co
8 Replies 8
if you want to reach 192.168.160.5 from the L3 switch, add a host route and specify the local interface on the L3 switch as the next hop:
ip route 192.168.160.5 255.255.255.255 local_interface_connected_to_FW2
Since you now have two ASAs, I would use policy routing on the L3 switch to direct half of your users to FW1 and the other half to FW2.
This command is not possible, it says
%Invalid next hop address (it's this router)
I setup the L3 port to be no switchport, put in an ip of 192.168.160.6 then tried
ip route 192.168.160.5 255.255.255.255 192.168.160.6
but unsuccessful.
thanks
Jeff
Jefferson Co
Jeff,
which sdm template are you running on the switch ? Can you post the output of:
3750#sh sdm prefer
#sh sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 6K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
number of IPv4 policy based routing aces: 0
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 0.875k
ok, so as not to confuse, forgot to comment on gpauwen's reply earlier, apologies. ok let me reiterate again the scenario.
* Our original setup is: Internet > Cisco ASA5520 > Cisco 3750 L3 switch > 2960-S
   distribution L2 switches
* On the L3 switch are connected the distribution L2 switches and its settings are
   switchport mode trunk, it does DHCP, it only has 1 IP route which is
192.168.120.254 is the Cisco ASA Port0 (inside) which has a Dynamic NAT rule on the Cisco ASA 5520 going to Port1 which is our primary ISP (outside)
Here comes the correction, we bought in a new firewall (other brand, not Cisco ASA) starts with the letter F.
We would like to retain the original IP 192.168.120.254 which is the FW1 Port0.
Our Cisco L3 switch was setup with HSRP before during the time it has a peer L3 switch. our virtual gateway for each vlan is:
192.168.20.254, 192.168.30.254, so the virtual gateway is: 192.168.x.254
In our office, we have several VLAN's, 10, 20, 30, 40, 50, 60, 70, 80, 90 and the 120 VLAN which is for the Firewall IP: 192.168.120.254
So in our Cisco ASA 5520, beside the dynamic NAT settings from inside to outside, it also has static routes like inside 192.168.20.0 255.255.255.0 192.168.20.254
It also has a default route 0.0.0.0 0.0.0.0 WAN1
Not sure if these gives more understanding of my issue.
Jeff
Jefferson Co
Jeff,
first of all, try to load the routing sdm:
3750#sdm prefer routing
With regard to your setup, do you currently do load balancing on your ASA (I would think you do since you have two WAN connections). It is going to be a bit tricky to integrate a second firewall into your setup, especially since all your LAN hosts use the virtual IP as their default gateway.
3750(config)#do sh
3750(config)#do show sdm prefer routing
"desktop routing" template:
number of unicast mac addresses: 3K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 0.5K
number of IPv4/MAC security aces: 1K
3750(config)#
Jefferson Co
Actually guys the issue has been solved. Here's what we did.
The default route in the L3 switch is 0.0.0.0 0.0.0.0 192.168.120.254, we've setup a new port on the L3, set it as no switchport and put in an ip address same as the new FW2 lan port (192.168.120.254), we've setup on the L3 port (192.168.120.253).
Then on the firewall, we've setup static routes going to each vlan and it's gateway is the virtual gateway set by the L3 switch.
I'm not sure if I'm able to explain the solution properly but basically issue solved and thanks for the input guys
Jeff
Jefferson Co
Jeff,
good stuff, glad you got it resolved !
