routing leased line internet traffic through ISDN Router
shoebwk
In my head office i have a 2600 leased line router connected to the internet.
my branch office is connecting to our internal servers through dialup ISDN (801).
how can i configure the ISDN router at both end to route the internet traffic from headoffice to the branch office connected via ISDN?
shoeb
12 Replies 12
Hello Shoeb,
basically, you do not need to configure anything on the branch office routers, just make sure that you have a default route on your head office router pointing to the leased line interface connected to the Internet. This way, all traffic not going to your internal networks will automatically be routed out to the Internet. Let´s say you head office router has two interfaces:
interface Serial0/0
description connected to Internet
ip address 212.24.23.1 255.255.255.252
interface FastEthernet0/0
ip address 192.168.1.1 255.255.255
The default route should point to Serial0/0:
ip route 0.0.0.0 0.0.0.0 Serial0/0
Assuming your servers are connected to FastEthernet0/0, the directly connected route will take care of traffic going to those servers.
Obviously you also need the route(s) to the branch office(s), but I guess you have those already configured (?)...
Does that make sense ?
GP
please see the attached diagram, which visualise what i want.
I want the router1 to provide internet access to the BR. Lan.
What routing i have to put in the both ISDN router , Router1 and Router2 ?
The users on the BR. LAN will have a gateway to Router1.
regards
in router 2 put in a default route pointing towards router1.
in router 1 put a default route pointing towards the router 3.
and here put any other routes for ur Ho lan(ie any other routers or layer 3 switches with vlans etc.. ) exists and routes for branches subnet pointing towards respective branches routers.
in router 3 u have to do nat (only if ur branches or ho lan are running on private ip's which i guess they must be) and put a default route pointing towards internet and summarised routes for the subnets being used in ur network towards router 2.
Are you sure that i put a default route on router 2 to point to router 1 or default route on router1 to point to router2.
And default route on router2 to point to router3
For outgoing traffic:
R1--Default Route-->R2--Default Route-->R3->Internet
For imcoming traffic
Internet-->R3(should have route for R1 LAN pool or NATed BRI IP pointing to R2)-->R2(should have route for R1 LAN pool or NATed BRI IP pointing to R1) -->R1
Let me know my assumption is correct.
Kannan.S.T.
SUPPOSE I HAVE FOLLOWING IP ADDRESSES
R1 (e0-192.168.10.1, BRI0=192.168.100.1)
R2 (e0=10.91.2.2, BRI0=192.168.100.1)
R3 (e0=10.91.2.3, BRI0=213.x.x.x)
does the following route and NAT are correct?
R1
ip route 0.0.0.0 0.0.0.0 bri0
R2
ip route 0.0.0.0 0.0.0.0 10.91.2.3
ip route 192.168.10.0 255.255.255.0 bri0
R3 (internet router)
interface ethernet 0
ip address 10.91.2.3 255.255.255.0
ip nat inside
interface serial 0
ip address 217.x.x.x 255.255.255.0
ip nat outside
ip nat pool test 217.x.x.x 217.x.x.y prefix 24
ip nat inside source list 7 interface serial 0 overload
access-list 7 permit 10.91.2.0 0.0.0.255
access-list 7 permit 192.168.10.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 s0
ip route 192.168.10.0 255.255.255.0 10.91.2.2
please correct it accordingly
Yes, It will work.
I corrected the following things from your post.
R2 (e0=10.91.2.2, BRI0=192.168.100.2)
R3 (e0=10.91.2.3, S0=217.x.x.x)
interface serial 0
ip address 217.x.x.x 255.255.255.252
No need "ip nat pool test 217.x.x.x 217.x.x.y prefix 24"
Kannan.S.T.
i have made final change in my diagram, where there is 2 remote site instead of 1 who require internet access.
IS the configuration OK for the attached Diagram
R-A (e0-10.100.10.1, BRI0=10.200.10.1)
R-B (e0=10.90.10.1, BRI0=10.200.10.2, BRI1=10.200.20.2)
R-D (e0=10.100.50.1, BRI0=10.200.20.1)
R-C (e0=10.90.10.2, S0=217.x.x.x)
R-A
R-B
ip route 0.0.0.0 0.0.0.0 10.90.10.2
ip route 10.100.10.0 255.255.255.0 bri0
Ip route 10.100.50.0 255.255.255.0 bri1
R-C
Ip route 0.0.0.0 0.0.0.0 bri0
R-D (internet router)
ip address 10.90.10.2 255.255.255.0
ip nat inside
interface serial 0
ip nat outside
Ip nat inside source list 7 pool test overload
rem ip nat inside source list 7 interface serial 0 overload
access-list 7 permit 10.91.10.0 0.0.0.255
access-list 7 permit 10.100.10.0 0.0.0.255
access-list 7 permit 10.100.50.0 0.0.0.255
ip route 10.100.10.0 255.255.255.0 10.90.10.1
ip route 10.100.50.0 255.255.255.0 10.90.10.1
Yes. It will work.
I think in the access-list the first ACE is not correct. It should 10.90.10.0.
Kannan.S.T.
Thanks Kannan, for all your help.
one question i want to check about connectivity between Router A, R-B & R-D
What will be the BRI's config as it will recieve call from two different number.?
Do i have to create 2 dialer for Router-B although it will just recieve a call.
can you send me a small config for the Router-B recieving two calls.?
just refer sample config. Modify according to your need.
I hope it will useful to you.
Kannan.S.T.
hi Kanan,
Thanks for your config. There is one doubt i need to check.
The BRI interface command can be set only for
interface bri0.
when i typr interface bri1 it give invalid command
i am using cisco 801
