Routing load balancing problem, Help!
Hello, I have 3 conections to my ISP. All of them are frame relay (E1), my problem is:
I configure as follow:
interface FastEthernet0/0
ip address 10.10.10.1
ip route 0.0.0.0 0.0.0.0 10.10.10.200 (ISP IP ADDRESS)
when I configure this like that everything works well internet is fast by example the video from www.youtube.com are ok.
When I Configure the next ip route and interface as follow
ip address 10.10.10.1 255.255.255.248
ip address 20.20.20.1 255.255.255.248 secondary
ip route 0.0.0.0 0.0.0.0 20.20.20.200
everything become slowly, I put load-balancing per packect and per destination but it still the same.
Each conection is a E1.
Even when I make a Traceroute in the first case is very fast but when I add the second ip route and third is really slow.
How can I fix this problem? I want to use of all my links making load balancing
By now the only traffic is from my laptop nobody else is using this connections.
Leo
mohammedmahmoud
Level 11
Level 11
Hi Leo,
There is either a typo error, or i can't analyze your situation, how is it that you are doing the default route to "10.10.10.200", while your FastEthernet interface is in the same subnet "10.10.10.1" and you say that you are connected to the provider via FR links, what is the IPs that you are peering with your provider with, please post the whole configuration if applicable.
BR,
Mohammed Mahmoud.
Ok my example wasn't right, here is my config
interface Ethernet4/1
ip address 200.109.243.129 255.255.255.248 secondary
ip address 200.44.154.185 255.255.255.248
no ip redirects
load-interval 30
interface Serial0/0
description Circuito 8151-0012318
bandwidth 1920
ip address 200.44.111.174 255.255.255.252
ip load-sharing per-packet
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
serial restart-delay 0
fair-queue
frame-relay interface-dlci 350
frame-relay lmi-type ansi
ip route 0.0.0.0 0.0.0.0 200.44.111.173
It works well but whe I add next ip route fron other valid network it becomes slow
example:
ip route 0.0.0.0 0.0.0.0 200.109.247.200
thanks
In order to try to isolate the issue, you should you use only 200.109.247.200 as a next hop for the default route. This should tell you if the "slowness" is introduced by the new link/new ISP.
Agree with Harold's suggestion, and please try to get the results of a direct ping with 1500 datagram to all your next-hops to see if there is any source of packet loss or delay on any of the paths.
HTH,
Mohammed Mahmoud.
