Routing router IPV6
Ragounee
As part of my project, I have to perform ipv6 routing between all the router, I did the same thing for ipv4 I managed to do ipv4 routing thanks to a similar post but for ipv6 It's the first time I've done it and I don't know if I started on a good basis. you can look my configuration
For IPV4 routing I succeeded through dynamic routing with the command below:
conf
eigrp 100 router
no auto-summarize
network 0.0.0.0
but this command does not seem to be compatible for ipv6 where it must be done otherwise.
So I tried to do a static routing:
From Router C:
ipv6 route 2001:0:CAFE:1::4/127g0/0/1
ipv6 route 2001:0:CAFE:1::6/127 S0/1/0
In this configuration, I have 100% ping from router C:
Ping  2001:0:CAFE:1::4, 100% received
         2001:0:CAFE:1::6, 100% received
When I add the other routes that's where the problem comes when I continue to the routes on C like for example:
Route IPv6 2001:0:CAFE:1::5/127 G0/0/2
Route IPv6 2001:0:CAFE:1::9/127 G0/0/2
test :
2001:0:CAFE:1::5 0% received
2001:0:CAFE:1::4 I receive more than 40/60% instead of 100%
I don't understand why, I guess I misconfigured my routes...
If you have a solution to do dynamic routing also in IPV6 where then if it is not compatible help me understand what I am doing wrong in my routing.
Thanks a lot !
Harold Ritter
Hi @Ragounee ,
The solution is available in this other posts:
https://community.cisco.com/t5/routing/routing-router-ipv6/m-p/4733939#M375700
