routing summary in eigrp
engamb1991
what are the difference between command
1) auto-summary
2) for ex :  ip summary address eigrp 1 90.0.0.0 255.255.0.0
We could consider auto-summary for classful but IP Summary for summarizing prefixes going out of an interface to the nearest supernet (VLSM)
Cheers!
Sumit
sumit menaria
EIGRP auto summarization applies to the entire EIGRP process. The ip summary-address command let's you manually summarize that network only out of the applied interface. You could have a network out that interface that could be summarized but other routes in other places that can't be summarized.
So if you have some networks like 10.0.0.0/24 10.0.1.0/24 10.0.2.0/24 10.0.3.0/24,then auto-summary will advertise 10.0.0.0/8 to the neighbors ,,however io summary address eigrp 10.0.0.0 255.255.252.0 will summarize the 4 prefixes into one.and the EIGRP neighbor will have 10.0.0.0/22 in its topology table.
Hope it helps.
thanks for your help :)
so the auto-summary for classful and the ip summary used for vlsm is that right
Cheers!
Sumit
