Routing table question
mohammedmahmoud
Level 11
Level 11
kindly, i have some trouble understanding these three routes when they appear in my routing table:
* candidate default
U per-user static route
P periodic downloaded static route
best regards, and thanks in advance.
* candidate default = 0.0.0.0/0 or other network that has been set via the "ip default-network" command.
U per-user static route = route that has been received via tacacs+ or radius for a given user on a dialer link.
P periodic downloaded static route = route that ha been configured using the following feature:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a008033a3a8.html#wp1001012
Hope this helps,
Thanks alot, but i've got a further question:
Does candidate default mean that the default route is configured on the router, or the default route is advertised from another router or both.
Thanks in advance.
