Routing To Firewall
NetworkGuy!
Hello
This is my topology as attached. I have site A (Switch A) connected to FW (all same subnet)
I know have Site B (Switch B) connecting to Site A (Switch A) however I want only 1 subnet out of Site B (10.20.100.0/24) behind Site A firewall - is this possible?
17 Replies 17
Just to add, as Paul says it will work, but you need to modify your next hops ie. you cannot have a static route on switch B pointing to the firewall IP, it needs to point to switch A's IP and then switch A has a route to the firewall and the same for routes from the firewall back.
Unless of course you are using EIGRP in the VRF as well in which case it will work.
Jon
Thanks Paul and Jon - now I have limited fibre connectivity between Switch A and Switch B
So can I do a L3 port-channel between two multilayer switches
example:
Switch A
port3.254
ip address 10.10.254.1 255.255.255.252
Port 3.253
ip address 10.10.253.4 255.255.255.252
vrf Test
Switch B
port3.254
ip address 10.10.254.2 255.255.255.252
Port 3.253
ip address 10.10.253.5 255.255.255.252
vrf Test
will the above work with VRF config?
Yes that should work fine.
Jon
