routing to HRSP virtual router
Yasser A. Sayed
hi everyone
suggestions are much appreciated
image 1 represents the normal ideal case
while as per Image #2 when there is a cut in fiber line between branch 1 & 2
Routers in branches (2 to 5) will not reach branch 1 router.  So another Virtual router represented by branch router 2 (second in priority) will exist to serve this group of workstations (Workstations  2,3,4,5)
At the same time, branch 1 Router  (as it will think it’s the only router in the group) will serve Workstation 1 as a gateway
The question is ; how is the HQ Workstation supposed to initiate a query to WS 2,3,4,5 as the routing will always be through WAN Type2 (cloud) due to higher priority
any suggestions ?
11 Replies 11
thanks for your reply
but i can't see how it may help;  as the destination (1.1.1.0/24)  will still be reachable...as the problem is not in the WAN
Assuming that i use IP SLA to monitor (1.1.1.5) and the fiber cut happens (as per the image), then the route (next hop) will be changed (from 10.10.10.2)  to another media (lets assume through  20.20.20.2). In this case HQ will be able to reach Workstations (2 to 5) but it will lose connection to workstation 1 (although it can be still reached as there is no problem in its WAN connection) ...right
This may be acceptable in this specific case (to lose one site out of 5) ...but assume larger number of sites and the fiber cut to be in the middle , then u will lose connection  to half of the workstations although there is a working WAN connection that can be used to reach them
Best regards
best regards
I think this can be done with EEM scripts on both sides.
On the branch routers, you need a script that shuts down its WAN interface when the HSRP state changes from Active to Standby.
On the HQ side you need an IP SLA for each WAN connection that tracks the other side of the WAN link, and removes the respective static route when the other side of the WAN is down.
I am currently testing this in GNS3, will send the results asap.
here is what I have come up with. On the HQ router, configure 4 IP SLAs and 4 routes with tracking. On all branch routers, configure the 2 EEM scripts. The script will shut down the WAN interface of a branch router if the router is not the active HSRP router, and the HQ router will only use the route pointing to the active HSRP router.
Shut all WAN interfaces that are not in use to start out with, so the script can unshut them. The interfaces assumed in the script are GigabitEthernet0/0 for the LAN, and GigabitEthernet0/1 for the WAN, change them according to your own interfaces.
HQ Router
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 ip sla 3 reachability
track 4 ip sla 3 reachability
ip sla 1
icmp-echo 10.10.10.2 source-ip 10.10.10.1
threshold 1000
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 20.20.20.2 source-ip 20.20.20.1
threshold 1000
frequency 5
ip sla schedule 2 life forever start-time now
ip sla 3
icmp-echo 30.30.30.2 source-ip 30.30.30.1
threshold 1000
frequency 5
ip sla schedule 3 life forever start-time now
ip sla 4
icmp-echo 40.40.40.2 source-ip 40.40.40.1
threshold 1000
frequency 5
ip sla schedule 4 life forever start-time now
ip route 1.1.1.0 255.255.255.0 10.10.10.2 track 1
ip route 1.1.1.0 255.255.255.0 20.20.20.2 101 track 2
ip route 1.1.1.0 255.255.255.0 30.30.30.2 102 track 3
ip route 1.1.1.0 255.255.255.0 40.40.40.2 103 track 4
ip route 1.1.1.0 255.255.255.0 50.50.50.2 200
All Branch Routers
event manager applet BRANCH_DOWN
event syslog pattern "Active -> Init"
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface GigabitEthernet0/1"
action 4.0 cli command "shut"
action 5.0 cli command "end"
event manager applet BRANCH_UP
event syslog pattern "-> Active"
action 4.0 cli command "no shut"
hello Georg Pauwen
many thanks for ur great effort...really appreciated..it was  very informative for me as this was out of my league
but if i understood right...this will reduce the network as per the newly attached image (hsrp3.jpg)
and the routing will be shortened to :
ip route 1.1.1.0   255.255.255.0   10.10.10.2 track 1 ---> ( which will be used as  track1 is valid)
ip route 1.1.1.0   255.255.255.0   30.30.30.2 102 track 3 ( will not be used as AD is 102 although track 3 is  also valid)
so again we will have access to WS 1,2 but not 3,4,5
is that right ??
Also what if we make all routes with same AD ?
again thanx for ur greatly appreciated idea
the configuration will make sure that only the WAN link to the active HSRP router is active. The only route in the routing table, from the perspective of the HQ router, is the route to the active HSRP router.
I am not sure I understand what you are after ?
hi again
the target is to have connectivity to ALL workstations at the same time  whatever/wherever the location of cut in the fiber
in this case (hsrp3.jpg)  (when there is a cut ) there will be 2 HSRP routers marked as active ( not just one), so theoretically there will be 2 routes . Only one will be used in routing table due to AD
so u will reach WS's connected to the router with its route in routing table and you will lose connection to the other WS's  connected to the other (HSRP Active) router
Hope i could make the idea clear
thanks again
The confusion comes from your description of the fiber link as being a switch. What are the routers connected to ? Each to a different switch ?
I guess it would help if you could provide a more detailed drawing of how your PCs are connected to the Branch routers, and how the branch routers are connected to each other.If all routers are in one HSRP group, the clients should have access toany of the routers no matter which one fails, otherwise the entire HSRP setup is flawed and needs to be reworked.
I have slightly adapted the configuration. Since you cannot track the routes (as there is always more than one route), you track just the reachability. At any given time, only the routes pointing to active HSRP routers are in the routing table (and it doesn't matter how many routers are active). Below is the script. The first two EEM scripts need to run on all branch routers. On the HQ routers, you configure 5 static routes, and 2 EEM scripts for each connected branch router:
All Branch Routers
HQ Router
track 4 ip sla 4 reachability
track 5 ip sla 5 reachability
ip sla 1
threshold 1000
frequency 5
ip sla 2
threshold 1000
frequency 5
ip sla 3
threshold 1000
frequency 5
ip sla 4
threshold 1000
frequency 5
ip sla 5
icmp-echo 50.50.50.2 source-ip 50.50.50.1
threshold 1000
frequency 5
ip sla schedule 5 life forever start-time now
event manager applet BRANCH_1_DOWN
event track 1 state down
action 3.0 cli command "no ip route 1.1.1.0 255.255.255.0 10.10.10.2"
action 4.0 cli command "end"
event manager applet BRANCH_1_UP
action 3.0 cli command "ip route 1.1.1.0 255.255.255.0 10.10.10.2"
event manager applet BRANCH_2_DOWN
action 3.0 cli command "no ip route 1.1.1.0 255.255.255.0 20.20.20.2"
event manager applet BRANCH_2_UP
action 3.0 cli command "ip route 1.1.1.0 255.255.255.0 20.20.20.2"
event manager applet BRANCH_3_DOWN
action 3.0 cli command "no ip route 1.1.1.0 255.255.255.0 30.30.30.2"
event manager applet BRANCH_3_UP
action 3.0 cli command "ip route 1.1.1.0 255.255.255.0 30.30.30.2"
event manager applet BRANCH_4_DOWN
action 3.0 cli command "no ip route 1.1.1.0 255.255.255.0 40.40.40.2"
event manager applet BRANCH_4_UP
action 3.0 cli command "ip route 1.1.1.0 255.255.255.0 40.40.40.2"
event manager applet BRANCH_5_DOWN
action 3.0 cli command "no ip route 1.1.1.0 255.255.255.0 50.50.50.2"
event manager applet BRANCH_5_UP
action 3.0 cli command "ip route 1.1.1.0 255.255.255.0 50.50.50.2"
i will try this one in GNS3 & give a feedback
thanx alot
