Routing to the internet
wilsonleonardy
Hi, I'm new to Cisco router.
I've been asked to create a network for a hotel internet service.
I'm currently configuring Cisco 1941 (non-wireless), and I've been stuck for a while now.
So, I have 2 network
192.168.0.* (ethernet0/0) and 192.168.1.* (ethernet0/1)
i connect my modem to ethernet0/0 and the client switch to ethernet0/1
I manage to ping the modem from a client, and it's working great.
the problem is i couldn't get through the internet.
is there any configuration that i missed?
and also, is it possible to manage the bandwidth to the client?
Thanks.
2 Accepted Solutions
Concerning NAT hat's what I had told you before, these soho models should nat everything entering their inside interface even if the src ip is not in the same subnet as the interface.
The static default route you've got is not correct so delete it and do this:
ip route 0.0.0.0 0.0.0.0 192.168.0.1
Because when doing a static route for a multipoint interface you should specify the next-hop and not the outgoing interface
but that's what you did so your Cisco router is going to ARP for every destination he wants to reach and if the soho router is not doing proxy-arp( which he surely doesn't ) then it can't work.
Regards.
Alain
Wilson / Alain
Apologies for jumping in as i don't want to cause any confusion but i suspect after reading the thread that the issue may be, as already suggested, that the modem is only natting for it's own local subnet. Could you, as Alain has already mentioned, try adding this to your 1941 config and retest -
int gi0/0
ip nat outside
int gi0/1
ip nat inside
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 101 interface gi0/0 overload
and then retest from a PC in the 192.168.1.x network (not the router itself).
Alternatively adding a route for the 192.168.1.0/24 network to the modem pointing to 192.168.0.2 would also be an option but not sure how easy this would be to do.
Can you try the above and retest.
Jon
72 Replies 72
vmiller
Level 7
Level 7
Your service provider needs to allocate a public IP address to you. at that point you perform Network address translation
to allow your clients to share the public address.
I have a public IP address from my ISP.
and i have applied the DHCP service on the router.
so logically there shouldn't be any problem.
on your router you need also a NAT, if you'd like to give the Internet access to your  private IP segment. Or proxy-server, which is may be more effective in your case.
you may need to post your current configs. But the general process is
- On your internal network router interfaces you have a "ip nat inside" statement
- On your public interface you have "ip nat outside"
- You then need a NAT  overload statement like
"ip nat inside source list 1 interface ethernet0/0 overload"
- you need a access list for the overload statement to match your internal IP ranges against something like "
access-list 1 permit any" will do it but you may want to make it more specific
- you need a default route statement out your pulbic interface "
ip route 0.0.0.0 0.0.0.0 ethernet0/0"
Hope this helps
Dave
Here is the current config of the router:
Using 1503 out of 262136 bytes
! Last configuration change at 23:51:33 UTC Sun Nov 6 2011
version 15.1
hostname HotelJakarta
boot-start-marker
boot-end-marker
enable secret 5 $1$qSkP$RaAzZCkUBcimthT07A7OO0
enable password xxxxxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool Guests
   network 192.168.1.0 255.255.255.0
   domain-name Guests
   dns-server 192.168.1.1
   netbios-name-server 192.168.1.1
   default-router 192.168.1.1
license udi pid CISCO1941/K9 sn FGL1532291Z
interface GigabitEthernet0/0
ip address 192.168.0.3 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool Guests 192.168.0.2 192.168.0.2 netmask 255.255.255.0
ip nat inside source list 7 pool Guests
ip route 192.168.1.0 255.255.255.0 192.168.0.1
access-list 7 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
transport input all
scheduler allocate 20000 1000
end
I'll try the NAT statement for sure.
thank you Dave and Konstantin.
but you don't translate your private IP into public IP in your config? or it will be done by your ISP?
and you don't hav a default gateway to your "WAN" interface.
isn't it supposed to be done by the internet modem? because the modem also have router capability.
given i have to get it done on the 1941 modem, what are the configs i have to put in?
what kind of modem do you use? can you configure it, which IP's have you configured on it?
If  the modem does for you the NAT translation, that you don'need to do it on your 1941, but default gatreway on it,  is still necessary , like "ip route 0.0.0.0 0.0.0.0
Konstantin is correct. The config statements I listed above were if you were bridging the public IP direct onto your 1941 ethernet 0/0 interface.
Be aware though that if your external modem is doing the NAT you may have to add a static router back to your 1941 ethernet 0/0 interface for the internal 192.168.0.0/16 addresses so that your internal networks cen get traffic back in.
how do i add a static router back to the 1941 ethernet0/0?
the LAN ip address for the modem is 192.168.0.1, therefore I set my ethernet0/0 ip address to 192.168.0.2.
so i should put it like: ip route 0.0.0.0 0.0.0.0 192.168.0.1
did i get it right?
you need to add something like 192.168.0.0 255.255.255.0 send to 192.168.0.2
On the modem that is. this sends all traffic coming in from the public modem to your 1941 router to send onto your internal networks.
"you need to add something like 192.168.0.0 255.255.255.0 send to 192.168.0.2"
having trouble typing.  Should be:
something like 192.168.0.0 255.255.0.0 send to 192.168.0.2
