Routing to two ISP
I've a routing problem on myrouter.
I've two Internet Provider connected to an interface of my router and many customers to other interfaces.
I want to direct some subnets of my customers to one ISP and some others subnet to my second ISP.
I'm connected to the first ISP with a static route and with BGP to the second.
Thanks in advance
Mathieu.
smehrnia
Level 7
Level 7
Hi Mathieu
for this task you could use Policy Based Routing, using route-maps and ACL to define different next-hops for different subnets. this way when you receive traffic form a predefined subnet on ur interface, it sends the traffic to the next hop you preset for it.
you can follow instructions here:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1000904
ADDed:
basically you create access lists to define the incomming traffic, then you include the access list in ur route map, using a Match clause, then Set ip next-hop.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
