Routing updates
kpradeep_venkata
Community Member
I'm facing a issues since couple of months.. I'm running EIGRP in our network and OSPF on MPLS network(connceted to our network), redistributing static routes in both.
the problem is that even though i remove some static routes my network is taking the same old path, routing updates are not happening properly.
Can anyone tell what could be problem??
Tharak Abraham
Level 7
Level 7
Is it a pure MPLS network or MPLS VPN's ?
If you are doing mutual redistribution, please ensure there are no loops !
Please do a traceroute xxxx source yyyy before/after removing the static route and see where your packets are hopping on and on..
Posting some relevant config snippets would be helpful too
it is pure MPLS and we have one IPLC as well. everytime i'm making the link down and up,then everything is working fine
its probably a looping issue, why dont you draw a sample topology and share with us.
