Routing with ASA 5506-X for Noobs
Deepspace
So please forgive my noob question, but I can't wrap my mind about this network problem.
I have a very simple setup.
Network 1 (outside) connected to Cisco ASA 5506-X and Network 2 (inside). On Network 1 there is "PC 1" with the IP 139.27.60.161/24 and is connected to Port 1 of the ASA which has IP 139.27.60.160/24. On Network 2 there is "PC 2" with the IP 172.16.170.110/24 and is connected to Port 2 of the ASA which has the IP 172.16.170.200/24.
Before I want to add all the specific firewall rules I want the basic routing function to work.
The interfaces of the ASA have their IP's. As I understood it there is nothing else I need to do in the settings of ASA to enable routing (apart from assign the IPs).
What I tried to do, was to Ping "PC 2" in Network 2 from "PC 1" in Network 1. "PC 2" has as Gateway the IP address of the ASA (139.27.60.160). Pinging in this direction worked. "PC 2" does have already a Gateway address (172.16.170.1). So I added a route "route add 139.27.160.0/24 172.16.170.200". But the Ping "PC 1" from "PC 2" still doesn't work.
Any suggestions where my error is?
Thanks to everyone for the help! :)
It appears that I just missed another route entry on one of the windows machines.
I also changed around the inside and outside network so that outside is on Port 1.
Seb Rupik
Hi there,
PC2 is routed on interface Gi1/2, which has a security-level of 0. It is trying to reach PC1 which is on a higher-security level interface.
For this reason you will need to explicitly permit the traffic flow with an ACL applied inbound on Gi1/2 .
cheers,
Seb.
Hello
Can you confirm - Maybe I have mis-interpreted what you have posted but you say an internal pc cannot ping an external pc but the external pc can ping the internal, If anything I would have expected the other way around to work only if you allowed echo-reply to enter your fw from the outside as I think @Seb Rupik highlighted?
Can you post the config of the firewall please?
Kind Regards
Paul
Alan Ng'ethe
Level 3
Level 3
As mentioned by Rupik, you have a security level 100 on the 'outside' interface and 0 on the 'inside' interface.
Remember the following rules:
-Traffic from a higher security interface to a lower security interface is allowed by implicit rules , by default
-Lower to higher will require an explicit rule to allow traffic
-Same security interfaces, traffic denied by default unless allowed using the command same-security-traffic permit inter-interface
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
