Routing with PPPoE
Hello
I have one issue about routing with PPPoE
i will show you diagram.i have configured PPPoE server on ISP router and client side on EDGE router.I will post the configs
The problem is i could connect from Edge to ISP and could get ip address but i cannot ping from PC to ISP
i wrote default route in Edge router  and back static route on ISP router.But i cannot ping from PC to ISP
I also checked with NAT but the result was the same.May be some one can explain me what may be the problem ? I also used dynamic routing and the ISP router get the PC network
SERVER SIDE (ISP)
bba-group pppoe test
virtual-template 1
interface GigabitEthernet2/0
no ip address
negotiation auto
pppoe enable group test
interface Virtual-Template1
ip address 10.10.10.1 255.255.255.0
peer default ip address pool pool1
ip local pool pool1 10.10.10.2 10.10.10.10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.10.2
no ip http server
no ip http secure-server
Client side (EDGE)
ip dhcp excluded-address 192.168.10.10 192.168.10.50
ip dhcp pool pool1
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
no ip domain lookup
no ipv6 cef
interface FastEthernet0/0
ip address 192.168.10.1 255.255.255.0
duplex full
no ip address
negotiation auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 60 either
dialer hold-queue 10
dialer-group 1
no ip http server
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
17 Replies 17
Hello
It stops on the edge
post the configs again you are currently using. Which IOS images are you using in GNS3 ?
Hello
@shaigsamadov490393996 wrote:
when i use NAT on dialer interface i even can not ping from ISP to edge
when i remove nat on dialer interface i can ping
At first glance you do require network translation but your nat ACL is incorrect-
an nat any any acl  isn't applicable
Try:
no access-list 10
access-list 10 permit 192.168.10.0 0.0.0.255
then test again
Kind Regards
Paul
