IPSEC in ASR 1001-X
jbaros
Hello Team,
I am planning to replace old End of Support IPSEC router with new ASR 1001-X. This router has included IOS as below:
Cisco IOS XE Software, Version 16.06.03
Cisco IOS Software [Everest], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.3, RELEASE SOFTWARE (fc8)
I would like to paste there IPSEC configuration. Will it work? I mean, do I need some specific IOS or license to run simple IPSEC?
My old IPSEC router is Cisco 3845, with IOS Version 12.4(20)T3, (c3845-advsecurityk9-mz.124-20.T3). There are no licenses, and IPSEC is working good.
ipsec4#sh license
ipsec4#dir flash:
Directory of flash:/
    1  -rw-    40031984  Apr 12 2011 06:44:06 +00:00  c3845-advsecurityk9-mz.124-20.T3
    2  -rw-        2751  May 15 2008 07:58:04 +00:00  sdmconfig-38xx.cfg
    3  -rw-     6389760  May 15 2008 07:58:34 +00:00  sdm.tar
    4  -rw-      931840  May 15 2008 07:58:50 +00:00  es.tar
    5  -rw-     1505280  May 15 2008 07:59:08 +00:00  common.tar
    6  -rw-        1038  May 15 2008 07:59:24 +00:00  home.shtml
    7  -rw-      112640  May 15 2008 07:59:36 +00:00  home.tar
    8  -rw-     1697952  May 15 2008 07:59:58 +00:00  securedesktop-ios-3.1.1.45-k9.pkg
    9  -rw-      415956  May 15 2008 08:00:14 +00:00  sslclient-win-1.1.4.176.pkg
   10  -rw-       12343  Oct 12 2011 11:50:02 +00:00  backup_conf
   11  -rw-       11091  Sep 12 2011 14:07:04 +00:00  ipsec4.txt
64012288 bytes total (12877824 bytes free)
Please let me know.. or show me way how to check it.
Thanks a lot.
Jozef
Jaderson Pessoa
Hello @jbaros
Look it:
More information here: https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
one thing to keep in mind is that encryption algorithms have evolved quite a bit since verison 12.4. So cutting and pasting might work, but it is better to manually change the IPSec parameters mentioned below:
--> Cisco no longer recommends using DES, 3DES, MD5 (including HMAC variant), and Diffie-Hellman (DH) groups 1, 2 and 5; instead, you should use AES, SHA and DH Groups 14 or higher.
