RSVP over IPSec tunnels
gmckay948bt
Is RSVP call admission control signalling supported over branch to branch IPSec tunnels?
Jon Marshall
Gordon
Do you mean can RSVP be sent down an IPSEC tunnel, as opposed to can RSVP deal with IPSEC flows ?
If so then yes as long as RSVP is using unicast then it should be fine. If RSVP is using mutlicast however then you may need to look into using GRE tunnels with IPSEC.
Jon
