RV016 One-to-One NAT problem
taknts1111
I have RV016 router with 5 public ip, i was able to use two wan ip x.x.x.45,46 ponit to my lan 192.168.1.45,46 server but when i use the thrid ip x.x.x.44 point to my lan server 192.168.1.44 all other on to on nat start have problem, once i enable x.x.x.44 = 192.168.1.44 my 1921.168.1.44 server can't access to internet, and other on to one nas traffic unstable, anyone have same problem? any fix and patch? please help.
smalkeric
Level 6
Level 6
Ensure your firmware release will support this one to one NAT. The problem was that, before the 2.0.13 release of the RV016's firmware, the RV016 was unable to perform NAT on subnets other than the one on which the RV016 resided. After the firmware upgrade, everything worked as expected thanks to the new feature on the setup page that allows a user to specify multiple subnets behind the lan side of the exterior rv016.
