rv042 will not allow access to RWW
thatsitsol
I had an older Linksys RV042 working perfectly until it blew up on me after 5 years of faithful service.  This new 'Cisco' with v4.0.0.07-tm firmware appears to be a dramatic step backwards - I'm tempted to call it a heap of junk!!!
1. The 'Smart Link Backup' is not working (our primary ISP failed today and it did *not* switch over to the backup ISP on WAN2 as advertised and more critically ....
2. It *will not* allow me to access the sbs-2003 R2 server using Remote Web Workplace.
From ouside the office I can connect to the server using a Remote Desktop Connection and my laptop clients can use the built-in sbs 'VPN' connections but not RWW.
I have duplicated all the port forwarding as per the old router, turned off the firewall and even tried forwarding 'all traffice to the servers external NIC all to no avail.  I get 'error 404' when clicking past the customary 'continue to this website ..." certificate warning.
I administer another 2 installations that use different routers and work flawlessly - do any of the gurus here have a solution please.
KariKostamo
Try logging into the router and going to Firewall and then General.  Disable HTTPS.
I had the same problem and this resolved it for me.
